2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Flashing Check Engine Light Clears itself after 20 seconds
Old Dec 12, 2013 | 04:11 PM
expedition2007's Avatar
expedition2007
Hello,
Recently I've had an odd problem happen with my '07 Expedition. Twice, after I accelerate hard to get on the highway, my check engine light has started flashing and then cleared itself within about 20 seconds. My car felt like it was mis firing while I was accelerating as well.
The check engine light flash is very random, it only happened twice in the past month, yet I have to accelerate hard quite often to either pass a car or enter the highway.
The misfire feel is NOT random. It happens every time I push the pedal to the floor. The acceleration is not smooth, truck feels like it is misfiring.
I took it to a mechanic today who could not pull a code. They checked the 4 coils (by swapping each out with a new one), but would not check the more difficult to get to remaining 4. In fact, they suggest either replacing all the coils (!!) as they say it is a domino effect in this truck or simply waiting for a code to present itself.
I've already had the #4 coil replaced and when it went bad, the truck was running on 7 cylinders...and I was lucky enough to be close to home when it happened. I'd prefer not to get stuck somewhere far away from home running on 7 cylinders or having to have the truck towed.
Are there any suggestions as to the cause or will I simply be chasing a gremlin until a code presents itself??
Thx!
Old Dec 12, 2013 | 04:41 PM
berry1234's Avatar
berry1234
There is a code. Take it do a dealer or another mechanic.
Old Dec 12, 2013 | 07:25 PM
bunky383's Avatar
bunky383
get it looked at soon because if your MIL is flashing, it can damage your converters.
Old Dec 13, 2013 | 06:13 PM
Henry Ford the 8th's Avatar
Henry Ford the 8th
Bunky383 is telling you right. Flashing MIL=cat damaging conditions, shut it off. Solid MIL=non-critical problem, OK to drive but have it checked out. Either one should set a code.
Old Dec 13, 2013 | 07:12 PM
bunky383's Avatar
bunky383
if the light goes out once you get up to speed, then the there should a history code stored. not all scanners can access history codes, some only show current codes, when the MIL is actually on.
JLP1
6.7L Power Stroke Diesel
Apr 10, 2018 06:40 PM
PAUL T.
1983 - 2012 Ranger & B-Series
Jul 27, 2014 09:00 PM
creed1212
13
Oct 19, 2007 07:10 PM
2002explorer
Modular V8 (4.6L, 5.4L)
16
Mar 17, 2005 10:37 PM
davesinsa
1997 - 2003 F150
May 11, 2004 08:14 AM
