hesatation
Old Oct 16, 2007 | 08:54 PM
creed1212's Avatar
creed1212
hesatation
my 03 expy hesitates on acceleration and the check engine soon light begin to blink, not good with cars so just need some type of idea before going to the dealer
Old Oct 16, 2007 | 09:21 PM
Greenscobie86's Avatar
Greenscobie86
A coil pack may have gone bad.
If the check engine light blinks, it usually means do not drive the car!(or at least not far) I would get the code pulled at your local Autozone(they do it for free) and then report back. GL!
Old Oct 16, 2007 | 10:14 PM
creed1212's Avatar
creed1212
just went to the store and the service engine soon light blinked a couple of times and just stayed on.
Old Oct 17, 2007 | 06:37 AM
Greenscobie86
Get that code read and tell it to us, then we will have some progress.
Old Oct 17, 2007 | 11:41 AM
creed1212's Avatar
creed1212
headed to autozone now
Old Oct 17, 2007 | 02:20 PM
creed1212's Avatar
creed1212
went to autozone they said it was code p0302
Old Oct 17, 2007 | 04:53 PM
P.K.'s Avatar
P.K.
cylinder # 2 misfire detected.
Old Oct 17, 2007 | 04:56 PM
P.K.'s Avatar
P.K.
cylinder # 2 misfire detected.here is where I got that info.http://www.2carpros.com/index.htm
Old Oct 17, 2007 | 05:44 PM
creed1212's Avatar
creed1212
how much will this cost to repair if i go to the dealer.
Old Oct 17, 2007 | 08:22 PM
dr cabela's Avatar
dr cabela
DO NOT GO TO THE DEALER!!!!!!!!!!!!!!!!!!!!!!
this is a simple repair that takes all of 15 min
that is a easy coil to replace and you might as well buy a new plug too
if i wasnt comfortable doing it myself i would just take it to your reg mechanic and see if he could do it for 25-30 bucks
Old Oct 17, 2007 | 08:56 PM
creed1212's Avatar
creed1212
sorry for the misinfo but it is the P0307 code cylinder 7 misfire, so do that make the job more difficult
Old Oct 18, 2007 | 10:23 AM
dr cabela's Avatar
dr cabela
some but not much
just take your time and move the hoses away
it is the second one from the back on the drivers side
if i were you i would drive by a mech shop and just ask how much to replace the coil
i would also get a plug too
easy job esp for a mech who has done it before
BTW i just replaced my #7 the other day
before that it was #4(real real hard to get to)
Old Oct 18, 2007 | 06:16 PM
fitzy67's Avatar
fitzy67
may be a good time to change all plugs depending on mileage. Get a Manual from the auto parts store.
Old Oct 19, 2007 | 07:10 PM
Oldtrucknut7077's Avatar
Oldtrucknut7077
If you do change plugs yourself, make sure the motor is completly cold. The threads of the plug holes are aluminum and it wouldn't take much to strip the threads. Also be careful not to overtorque the new plugs. Good luck-
Scott
