1998 Ranger No Headlights
Old Dec 21, 2005 | 08:46 PM
mike2002's Avatar
mike2002
I've got a problem with my headlights. when I turn them on the parking lights come on but no headlights. at first if I flashed the brights they would come on and stay on. now If I flash the lights they come on but do not stay on. I thought maybe the headlight switch so I changed it not the problem. anyone ever heard of the turn signal dimmer switch causing this problem.
Old Dec 21, 2005 | 09:02 PM
Ken00's Avatar
Ken00
I would suspect the multifunction switch, a common problem area.
Old Dec 21, 2005 | 09:57 PM
mike2002's Avatar
mike2002
when you say the multifunction switch are you talking about the dimmer turn signal hazard, in the steering colum.
Old Dec 21, 2005 | 10:07 PM
natebaker's Avatar
natebaker
I had a problem with my headlights being dim and sometimes not working at all. Check the bulb plugs. Mine melted bc I had bulbs that ran too high a wattage...
Old Dec 21, 2005 | 11:00 PM
RangerPilot's Avatar
RangerPilot
The multifunction switch is the blinker switch, window washer, and brights. Expensive part, ~$170 if I remember correctly.
His work fine on bright, so it doesn't seem like a bulb issue.
Old Dec 27, 2005 | 06:40 PM
mike2002's Avatar
mike2002
Ken you were right it was the multi function switch. picked one up at the dealer only 68 bucks. not bad considering all it controls. thanks for the help,
Old Dec 27, 2005 | 06:51 PM
Ken00's Avatar
Ken00
Glad to hear you got it fixed!!!
cliffhanger228
Sep 2, 2015 04:59 AM
mustangpt
Apr 22, 2015 09:59 PM
jgavac
Oct 24, 2011 07:23 AM
cowboypilot
1997 - 2003 F150
Jul 27, 2011 07:25 AM
nikolass
May 22, 2010 11:58 PM
