Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Doors Lock/Unlock While Driving?!
Old Dec 10, 2013 | 05:34 PM
berry1234's Avatar
berry1234
2008 Escape, while driving, the doors will lock/unlock themselves like crazy. Sometimes it's 20 times, others it's 100 times. Sometimes it won't happen for a day or two, sometimes it's everytime I drive it. When the car is off, remote works fine, car stays locked. Any ideas where to start?
Old Dec 11, 2013 | 10:22 AM
tomw's Avatar
tomw
The 'smart junction box' SJB is where the locks are controlled. I would suggest getting it checked. There may be spurious grounding or powering taking place on the wires to the door panel switches which signals the SJB to lock/unlock. The master switch on the armrest might have its wires chafing.
I had the locks cycle one time over the past 3 years, and I did not investigate further as it did not re-occur. The SJB responds to 3 things I can think of. The armrest switch, the remote, the auto-lock when in motion, and the signals from the keypad on the drivers door. There might be a check that the Ford diagnostic machine can check better as each SJB is programmed with the 'as built' equipment, and can not be swapped to a new unit until re-programmed or it won't work properly. I'm pretty sure they can query it as to what's going on.
tom
Old Dec 11, 2013 | 11:48 AM
berry1234's Avatar
berry1234
tom
Thanks. I think this will be a dealer fix! I will check for obvious exposed wires, etc first.
wrightbenz
Aug 10, 2017 01:47 PM
firebug
Feb 16, 2011 02:16 PM
98f150iowa
1997 - 2003 F150
Jan 24, 2008 05:27 PM
78 short
1997 - 2003 F150
Sep 26, 2005 08:32 AM
