Sponsored by: Real Truck
Wicked Vibration
Old Dec 9, 2013 | 03:01 PM
Bowcop's Avatar
Bowcop
Wicked Vibration
Hello gang...
I need your help. The truck is in my Sig 01 F250 5.4
Just got back from a long trip with it. Parked it for 3 days, all was running fine. Went to dinner Sat night and all was great, left the restaurant and as soon as I started the engine I noticed a slight vibration. As soon as I hit 42 miles per hour, it started shaking pretty good. I pulled over and checked under the truck to make sure I did not have anything I was not supposed to hanging down. Driveshaft looked good, nothing leaking from rear end or tranny. When it does vibrate, the Tach shows the unhappiness as well. This a.m. driving to work it was vibrating at all speeds and shifting was very rough, had a hard time deciding if it wanted to be in second or third gear. I don't think this is drive train issue... When it shutters and sputters at 40ish MPH, its almost like it loses power and I have to let off the gas. and then under power it shakes badly.
I had the super chip settings for performance tow when this started and then I changed it back to stock settings, thinking it might help, which it only got worse. Changing the settings with the Superchip you have to disable the fuel system and I do this by pulling the fuel pump fuse under the hood in the power distro box. I am at witts end here !!!!
I think the ujoints are still good, the oil and tranny fluid are spot on. Hubs are locked but in 2WD. Had all the front end replaced 15K miles ago. Brand new tires and wheels in Sept, front end alignment done at same time, front brakes were 90% and rear brakes at 20%
Any ideas boys?
TIA
Tim
Old Dec 9, 2013 | 05:41 PM
Bowcop's Avatar
Bowcop
Anyone have any ideas?
Old Dec 9, 2013 | 05:46 PM
redford's Avatar
redford
FTE Leadership Emeritus
Where do you feel the vibration? In the seat, the steering wheel, the pedals, or the radio *****?
You mentions shuddering and sputtering. Is this a vibration or an engine miss?
Old Dec 9, 2013 | 08:32 PM
Bowcop's Avatar
Bowcop
this is what I know for sure when you accelerate it vibrates pretty bad and you feel it in the steering wheel. When you give it gas it shutters pretty bad vibration wise, and then when you let off the gas just kind of Coast at speed it goes away. If I stop and put it in park, it vibrates. When I stop and put it in neutral with my foot on the brake it still vibrates even in neutral.which leads me to believe its in the motor. The idlel is somewhat rough, as if its not getting enough gas
Old Dec 9, 2013 | 08:50 PM
Bigpipes 35's Avatar
Bigpipes 35
My guess is a coil pack, do you have a check engine light on??
Old Dec 9, 2013 | 09:25 PM
Frdtrkrul's Avatar
Frdtrkrul
I had this problem with my 99 F150 5.4L it turned out to be a bad spark plug. Replaced all of them and problem solved.
Old Dec 9, 2013 | 11:29 PM
Bowcop's Avatar
Bowcop
Tnx for the reply... How much of PITA is it to change the plugs? Looks like more than I want to chew....also I have no engine lights
Old Dec 9, 2013 | 11:39 PM
Bowcop's Avatar
Bowcop
.okay I started the engine and it's vibrating really bad I put it under a little bit of a load and its smooths out. I have an error code of 01 - P 1000
Old Dec 10, 2013 | 12:10 AM
Frdtrkrul's Avatar
Frdtrkrul
F150s it'll bring a man to drink to change the plugs. Its tight under my hood. You should have plenty of breathing room. P1000 means the reader was unable to complete the scan.
Post number 3: https://www.ford-trucks.com/forums/8...ble-codes.html
Have to scroll a bit to find it but its in order.
Old Dec 10, 2013 | 04:23 AM
redford's Avatar
redford
Before you go throwing parts at an unknown problem (and wasting money) have the truck scanned for error codes and PENDING codes.
Old Dec 12, 2013 | 04:58 PM
Bowcop's Avatar
Bowcop
I'll post when the scan is done....
Tnx boys!
F7 Firecat
Jan 13, 2020 01:48 PM
northwindone
Apr 13, 2018 10:27 AM
allen720
Apr 19, 2012 06:48 AM
markt1993
6.4L Power Stroke Diesel
Feb 23, 2012 12:50 PM
jason1
1983 - 2012 Ranger & B-Series
Nov 18, 2008 06:03 PM
