i have an 87 f150 with 302 efi. i rebuilt the engine in my engine class and it ran before. now i put the engine back it in starts with starting fluid. i replaced the fuel pump relay and main relay but the fuel pump relay does not prime the fuel pump when the key is on or trying to start. but i know it has power because when i take the relay cap off and touch the connections together manually i can then hear the fuel pump build up pressure. what could it be? new pump or bad wires/ connections. or does my truck turning over with out the key have anything to do with it.
More than likely a bad computer but you need to ground pin #6 on the test connector with the key on and see if they run then.
If they do then short pin #2 to pin #6 and see if they still run all the time with the key on.
You also need to make sure the small black wire with a green stripe on it has a good connection at the NEG post of the battery.
Alright so I grounded pin 6 and the fuel pump came on. Barley made a humming noise. And then when I shorted #2 and #6 the fuel pump came on a little louder when I turn the key one. So is it a bad computer?
