96 f150 heat
Old Dec 9, 2013 | 06:45 PM
trucker11067's Avatar
trucker11067
96 f150 heat
I have a 96 f150 the heater blows hot air when its 60 degrees or higher outside but when its cold outside it blows cold air its like you got the AC on what can be wrong its got a 4.9 engine
Old Dec 9, 2013 | 07:25 PM
DBGrif91's Avatar
DBGrif91
I'm not saying you didn't check it, but the most common cause of improper heater output is low coolant. If you've got hot air outside, there's not as much need for assisted heat and it will feel like normal. If you've got cold air outside and not enough coolant to provide heat, it's going to blow cold air.
Check the coolant in the radiator and make sure the reservoir is properly filled.
Step 2 is bring the engine up to temperature and check the heater hoses. If the heater core is plugged, one hose will be hot and the other will be cold.
Old Dec 9, 2013 | 07:56 PM
blkF250HD's Avatar
blkF250HD
As mentioned, low coolant, clogged heater core, stuck open thermostat, binding/misadjusted blend door.
Old Dec 9, 2013 | 10:03 PM
trucker11067
Thanks guys I'll check that stuff
fordowners
Jan 15, 2024 07:06 AM
Howie Long
1983 - 2012 Ranger & B-Series
Nov 20, 2016 10:36 AM
mlelah
26
Jan 10, 2015 02:27 PM
handthill
Mar 4, 2012 07:20 PM
Jayme Duty
Dec 6, 2009 08:35 PM
