Help me with a minor cable replacement, ALT already swapped
Ok, I just don't wanna screw this up. It appears my alternator was already swapped at one point. I have an 89 f250 with a 351.
Truck is a plow truck and started acting up and showing 8-9 volts on the meter. Finally quit. Took it to the parts store, alternator tests bad. I order a new 100 amp alternator. Take it out and the connectors are different. Not only that the 4ga cable is corroded and snapped off, likely my whole problem.
Here is the alternator that is on my truck.
It appears to be a 130 amp 3G but I am NO expert? Also before I go taking apart the harness what am I gonna find?
Here is a pick of the wires coming from the alternator going to the solenoid and a little plug in connector.
Any help would be appreciated! I need this truck up and going again fast.
Thanks,
Z
Thanks,
Z
Yea replace the cable end, solder a new one on or replace the cable as a whole.
Clean those connections shown in second shot, wire brush that rust off the posts and all cable ends until see clean copper.
70-360fe
34
03-11-2012 09:08 PM
Moore558
13
01-27-2008 12:46 PM
