Tailgate Bracket
Old Dec 7, 2013 | 02:29 PM
4df150's Avatar
4df150
Tailgate Bracket
Anyone knows the purpose of this bracket on the passenger's side fo the tailgate????
I've got a "Line of Fire" LED taillight bar and this bracket is in the way.
Old Dec 7, 2013 | 02:38 PM
senix's Avatar
senix
To keep the tailgate from coming off the hinges.
Old Dec 7, 2013 | 06:26 PM
720Deere's Avatar
720Deere
I still haven't fully figured out their intentions with that one. Both the piece on the tailgate and the one on the truck have been gone from my truck for over 50,000 miles now. I took them off to install a light bar just like you intend to do. My brother has also removed his.
The two pieces never made contact on my truck so I can't figure out how it can help with aligning or retaining the tailgate. This much I can tell you, your tailgate won't fall off without it!
Old Dec 7, 2013 | 08:46 PM
TRENT310's Avatar
TRENT310
My 2011 never came with this piece, I did notice it on newer models though especially ones with the step and/or wiring into the tailgate.
Tailgate inner surface not bedlined?
Old Dec 7, 2013 | 09:24 PM
720Deere's Avatar
720Deere
When you have the step and stripper pole, the tailgate is covered with an ignorant plastic bedliner piece. I never realized those pieces weren't on the non-step tailgates. Maybe those brackets are related to the step cantilevering the tailgate. My fat a$$ uses the step all the time and I've never noticed any movement without the brackets in place.
Old Dec 7, 2013 | 09:46 PM
TRENT310's Avatar
TRENT310
Yeah I thought it was to provide additional support for the tailgate but they don't touch when the tailgate is opened so as far as I can tell it's supposed to prevent side-to-side shifting of the tailgate on the hinges and reduce any play that may be present.
I don't have frillsy stuff like that on my truck so I just have the regular tailgate which doesn't have this piece, but the threads are present.
Old Dec 7, 2013 | 10:38 PM
4df150's Avatar
4df150
Thanks guys for the input. I thank the bracket is coming off and the LED bar is going on....
Old Dec 8, 2013 | 10:13 AM
jonrjen's Avatar
jonrjen
This is one thread I sure did appreciate, time to remove mine and put the light strip in place.
Old Dec 8, 2013 | 11:39 PM
Chad149's Avatar
Chad149
It's that the factory "tuffbed" liner?
Most of those light strips attach with double sided tape, and I found out the hard way tape does not stick to it. Ended up giving mine to my brother in law.
Old Dec 9, 2013 | 08:55 AM
4df150's Avatar
4df150
Yes, it's the "tuffbed" factory lining. On my F-150 the LED bar had screw tabs on it and I used stainless steel screws to install it. I have to check my new LED bar to see if it also has the screw tabs.
Old Dec 9, 2013 | 09:06 AM
SavageNFS's Avatar
SavageNFS
To my knowledge it provides support for the tailgate assist step and rail.
Old Dec 9, 2013 | 01:04 PM
Ferguson65's Avatar
Ferguson65
I have to agree with Senix here. It keeps the tailgate on the hinges unless you intend to take it off. I know on my 04 F150 (did not have bracket) I had it happen one time, but if you get enough debris between the gate and bed then try to close the gate, it'll flop off the hinges and you get to try to catch it. These damn tailgates are heavy and that's no fun. I've had my gate off a few times with the bracket on the 13 and it needs to be in just the right position for it to come off.
saskowner
Apr 7, 2018 01:06 PM
PITS
6.7L Power Stroke Diesel
Jan 17, 2012 05:30 PM
Subsailor1127
6.4L Power Stroke Diesel
May 26, 2010 06:01 AM
ctfordguy
2004 - 2008 F150
Mar 22, 2004 08:51 PM
