Gas Tank
Old Dec 7, 2013 | 09:55 AM
rob8210's Avatar
rob8210
Gas Tank
I have a 99 Explorer XL 4 door 4 wheel drive 4.0l motor. I have to replace the fuel tank, does anyone know if it is a pressurized?
Old Dec 7, 2013 | 07:00 PM
shorod's Avatar
shorod
What do you mean by pressurized? The tank itself will not be pressurized once you open the fill fill cap, but the fuel line to the fuel rail could still have pressure it in. You'll want to pull the fuse for the fuel pump or unplug the inertia switch and let the engine run until it stalls, or install a fuel pressure tester on the fuel rail and release the pressure using the tester.
-Rod
AnnoyedEasy3
Bronco II
Mar 30, 2015 01:12 PM
oldfart
May 28, 2012 10:39 AM
justforkicks
Dec 17, 2011 06:51 PM
Onus
Sep 18, 2011 08:23 PM
1994_F150_302M
Sep 30, 2005 04:18 AM
