Fuel Pressure psi?
Old Sep 18, 2011 | 05:20 PM
Onus's Avatar
Onus
Fuel Pressure psi?
Wondering what the fuel pressure should be with a 91 351w. Going to rig up a gas can for the winter as the fuel tank quit. Yes, its not the right way but, i don't feel like dropping the tank, and getting a new tank, fuel sender, fuel pump.
Old Sep 18, 2011 | 05:22 PM
jplinville's Avatar
jplinville
Instead of using a gas can, use an old aluminum beer keg. I did that with an old Jeep I had. I strapped it to the inside of the roll bar, and ran the fuel line from there.
Old Sep 18, 2011 | 05:26 PM
Conanski's Avatar
Conanski
You need something that will generate 40-45psi at the motor at an 80-90l/hr flow rate.
Old Sep 18, 2011 | 06:53 PM
Onus's Avatar
Onus
That beer keg is a good idea, now where do i buy one. I don't drink, plus i'm only 19 but, i don't plan to for many reasons. Thanks conanski now i know what to shop for. It was a disappointment was gonna change the oil, start the truck up move it of the grass and bleed the brakes.
Old Sep 18, 2011 | 08:23 PM
Onus's Avatar
Onus
Decided to not do this as it would be 50 or so more than the after market pump for a new replacement pump and tank. Tank is $70 and pump is $70. Not to bad i suppose. After market pumps were about $90.
87beast
Jun 29, 2024 12:15 PM
rob8210
Dec 7, 2013 07:00 PM
cajunsuperduty
Jun 29, 2013 10:12 PM
oldfart
May 28, 2012 10:39 AM
dr strangelove
Sep 9, 2010 04:13 PM
