Need Help Wont Start
Old Dec 9, 2013 | 02:07 PM
MrsCopenhagen's Avatar
MrsCopenhagen
We wire two switches into the cab. One for the glow plugs and the other for my fuel injection pump. I hold the glow plug one down for 10 seconds and switch on the fuel injection pump one. then turn the key to start
Old Dec 9, 2013 | 02:34 PM
irhunter's Avatar
irhunter
OK, I would double check that you are getting 12v right at the IP (with a test light or meter) when your in-cab switch is on. I am sure, you are sure all is well with your added wiring, but I suggest a second check.
If you have 12 v. right at the IP, then I would suspect the fuel shut-off solenoid.
I don't know if the FSS on the IDI can be gutted to test for function.
Roy
Old Dec 9, 2013 | 02:48 PM
MrsCopenhagen
I have two switches in my cab, one for the glow plugs the other for my fuel injection. I hold down the glow plug one for 10 secs turn on the fuel injection then turn the key to start
Old Dec 9, 2013 | 02:53 PM
irhunter's Avatar
irhunter
Right. I am just suggesting double checking at the IP that you are getting 12 v. there when your in-cab switch is on.
BTW, while standing near the IP, you should be able the hear the FSS click when someone else throws the in-cab switch. Sometimes the plunger in the FSS gets jammed up; sometimes the FSS is just pooched.
Old Dec 9, 2013 | 03:11 PM
MPoulson's Avatar
MPoulson
That's good enough to get you home and maybe to work the next morning but you and Pop should really set aside a day to figure out what shorted and smoke checked your wiring harness.
We don't want to hear about a truck fire and two screaming alphas!
I would start at the spot where you actually see the burned wire.
I assume (hope) there are blown fuses or a popped fusible link? That may be the wire you see burned in two.
Old Dec 9, 2013 | 03:37 PM
MrsCopenhagen
Pops doesn't have time. We both work till after dark. And he thinks it a wire under the dash shorting out. And ya'll know what it looks like under there....
Old Dec 9, 2013 | 03:47 PM
bobby22m's Avatar
bobby22m
Where you guys located? I might have a shop that I can let you use to fix it.
Old Dec 9, 2013 | 03:55 PM
MPoulson's Avatar
MPoulson
Every day!?
It's not as bad as it looks but, in any case, you (or someone) are going to have to deal with it.
Old Dec 9, 2013 | 05:25 PM
MrsCopenhagen
We own a tire shop. Its just that it was running lastnight and has decided not to run this morning for me
jtipton331stroker
Aug 24, 2011 05:53 PM
RP27G8G
Oct 19, 2008 09:12 AM
'87BroncoII
Bronco II
Oct 16, 2004 11:33 PM
SPFDRum
Jan 19, 2004 02:12 PM
