Speedometer Still Doesnt Work
Old Dec 6, 2013 | 07:08 AM
rbrungard2012's Avatar
rbrungard2012
I need some assistance if somebody can help it's much appreciated. I have a 1983 F-250 with a 4-speed automatic trans. My speedometer is not currently functioning at all. I have already replaced the plastic drive gear in the transfer case and the entire cable from speedo. down, but no results. I can rotate with my fingers or a drill and get response... This leads me to believe it must be in the transfer case but I'm not really sure. Any ideas?
Old Dec 6, 2013 | 10:26 AM
brokeasajoke's Avatar
brokeasajoke
Not for sure on your t-case but a borg 1356 ( in my 88 and 96) has a plastic worm gear that drives the cable gear. If i stick my finger in the hole i can feel it. It is held onto the shaft with a single ball bearing which acts like a keyway.
Old Dec 6, 2013 | 12:21 PM
ifrythings's Avatar
ifrythings
If you replaced a chewed up driven gear on the cable end, the drive gear in your transfer case will be shot, now why didn't ford make the drive gear metal I don't know, if they would have, we would only need to replace the driven gear and not have to rip apart tranny's and transfer cases to repair these drive gears.
Old Dec 6, 2013 | 12:30 PM
rbrungard2012
What would you say is the best way to go about checking and replacing internal parts?
KRinAZ
36
Aug 30, 2017 11:15 AM
srqlandy
Mar 4, 2012 01:37 AM
StrangeRanger
Jun 26, 2005 12:33 AM
djmac
Offroad & 4x4
May 9, 2004 08:54 AM
