wiper spindle woes
Old Dec 6, 2013 | 02:42 AM
Bluey Zedoff's Avatar
Bluey Zedoff
wiper spindle woes
Hi guys.
Got some weird, scary thing happening with the wipers. Haven't had the truck long, and this is the first time I have gotten the wipers sort of half going. However, it appears I may have bought the wrong wiper arms or something weird is going on.
The spindle thing is smooth, yet, when I slip the shaft over it, it just falls off.
When I turn the wipers on without having wipers connected, only the tip of the spindle moves back and forward unless I loosen the nut. The one on the other side goes back and forward, but it moves in such a haphazard way that it looks like its gonna fall apart.
this is the spindle thing and this is the wiper arm which shows the splined shaft and insert piece.
Any ideas, guys?
I should run a video to show you what it aint doing...
Old Dec 6, 2013 | 08:06 AM
CharlieLed's Avatar
CharlieLed
See page 72 of the 2012 Midfifty catalog. Cowl Pivot Drum Repair kit, part number 3005...$12.50 US.
Old Dec 6, 2013 | 08:10 AM
ALBUQ F-1's Avatar
ALBUQ F-1
A 55's setup is different than a '51-'52's, but it looks like you are having a similar problem to the ones that plague us. In your case all you need to do is order a new pivot assembly (or two). The part the wiper arm snaps onto is supposed to be knurled to match the arm, and is supposed to be firmly attached to the pivot shaft.
Old Dec 6, 2013 | 02:22 PM
Bluey Zedoff
Thanks guys. I never even gave it a thought that it could be worn out. Doh!
Just thought (as usual) that I was doing something wrong.
Learn something every day.
regards
railrode1
Mar 3, 2018 06:09 PM
cbutcher
15
Dec 10, 2010 03:33 PM
Vegas Ernie
Mar 29, 2008 06:08 PM
rsylvstr
1997 - 2003 F150
Jan 19, 2007 06:45 PM
53Merc
13
Jul 27, 2005 11:10 PM
