Under cowl Wiper Assembly Install
Old Jul 10, 2005 | 04:48 PM
53Merc's Avatar
53Merc
Arrow Under cowl Wiper Assembly Install
I never removed the assembly and I'm about to install it with a Chrco Electric Motor.
How so I tell which way it goes into position?
GW
Old Jul 10, 2005 | 10:12 PM
theGman's Avatar
theGman
The shaft ends face you and angle down more than up due to the rotation.
Old Jul 11, 2005 | 05:03 AM
53Merc's Avatar
53Merc
I'm having trouble visualizing this... do you mean the shafts that go through the cowl an dactually drive the wiper arms on windshield?
GW
Old Jul 11, 2005 | 07:34 AM
LEckart's Avatar
LEckart
Do you have a Service Manual as there is probably a picture of the wiper assembly in it. If not how about a Mid Fifty catalog, they show the wiper assembly and it might help understanding how it works. The two wiper arm pivot shafts go through the cowl, held in place with a chrome ferrule and nut. There are arms that extend from each pivot shaft under the cowl toward the center where they attach to the wiper motor pivot arm. This probably doesn't make sense but if you saw a picture it probably would. You may not have all the pieces. Check the illustration in the Mid Fifty book.
Old Jul 11, 2005 | 11:21 AM
Earl's Avatar
Earl
I've been trying to finish stripping my cab and I'm almost there. If I can get a photo of the wiper assembly in a reasonable timeframe (), I'll see if I can post it for you.
Old Jul 11, 2005 | 01:12 PM
53Merc's Avatar
53Merc
Is that in position George?
That would be a great help!
As they say, A picture is worth a 1000 words.
GW
Old Jul 12, 2005 | 01:06 AM
rhw's Avatar
rhw
hmmm... speaking of wipers...
Has anyone ever shoved/welded/stuffed a wiper assembly from an old(67) mustang into a 54 f100? Reason I would like to try is because of the cool foot pedal washer and wiper switch I have on the floorboard of my 67 mustang. Did I say "old" mustang? I forgot what audience I'm adressing! I mean my late model, newest daily driver! Thanks!
Old Jul 21, 2005 | 09:46 PM
Earl's Avatar
Earl
Finally got all the stuff out of the cab and the wiper assembly is the last thing to remove. Here are three photos of the assembly from under the dash.
The three photos are all taken from the same vantage point and move left to right under the dash - or is that right to left, but upside down? Anyway, the three photos show the one side, the center, and the other side portions of the assembly in order.
If you need any more info just yell.
Old Jul 22, 2005 | 09:38 AM
Fat Fendered Ford's Avatar
Fat Fendered Ford
A couple more pictures that may help...
Kevin
1953 Ford F-100
Go Illini
Old Jul 23, 2005 | 05:31 PM
53Merc's Avatar
53Merc
Thumbs up You Guys are the Cat's MEOW!
Thanks Kevin & George!
Really appreciate it.
Just got back from a 4 day road trip with my youngest, Alex, 13.
She wanted to see the Lucille Ball/Desi Arnez Museum in Jamestown and we camped on Chautauqua Lake and visited the Chautauqua Instituion...say Arlo Guthrie perform Friday Night!!!
Great trip, great father daughter time, and the truck worked well...except for the passenger side interior door handle!
GW
Old Jul 23, 2005 | 09:38 PM
tomoto's Avatar
tomoto
my wiper motor has 2 pivot shaft coming out each end of the motor .no linkes
Old Jul 24, 2005 | 07:54 PM
53Merc's Avatar
53Merc
George, Kevin et al:
I was given a Mopar Wiper Motor and a mounting bracket so I can have electric wipers rahter than those vacuum ones that suck...literally
The Wiper motor pivot shaft on my Mopar Motor seems too short to accomodate the Ford linkage arms.
Aany one had a similar problem or gone through this adaptation and can give me some advice?
LMK
GW
Old Jul 27, 2005 | 06:44 PM
Cowman's Avatar
Cowman
I used the wiper motor from a Cherokee (classic 90's vintage). It bolted in very easily. I only enlarged the 3 stock F100 mounting holes a little and everthing matched up very well. I also used the steering column from the Cherokee so I was able to wire in the delay wiper function also. I have some pics in my gallery of the wiper. Let me know if you need any info.
Good luck
Old Jul 27, 2005 | 11:10 PM
53Merc's Avatar
53Merc
Thanks Cowman, like I always say... a picture is worht a 1000 words!
GW
Craftsman027
Oct 10, 2010 07:06 AM
trevwilliams
Apr 20, 2009 07:35 AM
sparkyrhett
Dec 30, 2007 07:31 AM
Busa01
3.8 & 4.2L V6
25
Nov 29, 2004 10:39 AM
