Wiper Arm Pivot Mounting
Old 12-08-2010, 11:51 PM
cbutcher's Avatar
cbutcher
cbutcher is offline
cbutcher is starting off with a positive reputation.
Ok I have read about 100 posts on wipers and wiper arms, but can't find any mention of this, and the manual has nothing.
I have two Wiper Pivot shafts , both work and rotate but I can not figure out how to mount the wiper arms to them.
There is no knurled round **** on them. I do not know if I have some
weird 1960 only model pivot, or just missing the knurled **** ?
Do I need to replace the Wiper Pivots with new?
Old 12-09-2010, 12:29 AM
ibuzzard's Avatar
ibuzzard
ibuzzard is online now
Gone But Not Forgotten
ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.
Craig,I will check my truck tomorrow,but I'm almost positive that you should have a splined shaft off the wiper linkage that mates to the matching female end of the wiper arm.It is not a one-off design just for 1960.If you've got a factory manual,and I recommend you get one, there may be a decent exploded view drawing.
Old 12-09-2010, 01:00 AM
cbutcher's Avatar
cbutcher
cbutcher is offline
I got this manual on CD but can find no wiper diagrams.
I feel the PO might of pried the wipers off and took the little
**** off with the arm.
Is there A better manual?
Thanks
Craig
Old 12-09-2010, 01:24 AM
ibuzzard's Avatar
ibuzzard
That will be your best manual for repairs.There is a 57-63 parts and accessories disc you can get from hi-po parts.They sell on ebay,it's under 30.00,and the illustrations section is often very helpful.I'll check a vendor catalog or two to see if there are drawings,and replacement parts shown in them,but it will have to be tomorrow.
Old 12-09-2010, 06:46 AM
bobbytnm's Avatar
bobbytnm
bobbytnm is offline
Roast em' if you got 'em
bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.bobbytnm has a spectacular reputation.
Wow, no splined ****? I've never heard of a wiper pivot without the splined ****. I think you're probably right, the PO must have "fixed" them for you. From looking at the picture I'd say you need to get new pivots
Bobby
Old 12-09-2010, 07:23 AM
3414
3414 is offline
3414 is gaining momentum as a positive member of FTE.
I had that problem once. On the 57 to 60 The knurled part is not listed as a seperate item, and it is a part of the pivot assembly. The knurled part looks to be a die cast part, and is swaged onto the pivot shaft end. With age and corrosion it can easily break off if you use too much force to remove the wiper arm.
I could not find a good, reliable way to reattach this piece, so I just installed a different pivot assembly. If you are looking at a used pivot assembly, closely inspect that area to make sure you are getting a good one.
Hope this helps
Old 12-09-2010, 09:20 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
Dennis Carpenter: P/N 8A-17566-RK
http://www.parts123.com/parts123/yb....Z5Z5Z50000024G
There ya go! My truck's PO used pliers in some manner that completely egged out the knurled piece, so I'll be doing this too.
Old 12-09-2010, 09:27 AM
3414
3414 is offline
Interesting. Wish I had seen those two years ago. If anyone buys and installs these, let us know how they attach, image has something that looks like a set screw.
Old 12-09-2010, 10:41 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Yep, the originals were staked over like you said, I don't know how you could remove old ones and have enough material to re-stake. I'd also assume these are harder metal as a set screw wouldn't last long on the pot metal originals.
Old 12-09-2010, 12:15 PM
cbutcher's Avatar
cbutcher
cbutcher is offline
Thanks
I ordered the parts and will let you know how the install goes.
ALBUQ F-1 Great catch, I looked through Dennis's catalog and did not see these.
Thanks everyone for your help.
Craig
Old 12-09-2010, 01:01 PM
bobbytnm's Avatar
bobbytnm
bobbytnm is offline
Ross,
I have a set of wiper pivots and bracket for a 51/52 truck if you need them. Let me know
Bobby
Old 12-09-2010, 03:37 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Thanks Bobby, I may take you up on that, but I'm still try to do something custom and electric. I have two '52 electric setups and a VW bug system, plus a Cavalier motor... with no rain in the last 2 months, it isn't high on my list!
Old 12-10-2010, 12:31 PM
bobbytnm's Avatar
bobbytnm
bobbytnm is offline
Ross, Its just the basic bracket set-up with 2 pivots
I've been considering what to use for a wiper motor as well. Not a big concern with out amount of precipitation....lol
Bobby
cbutcher...sorry for the hijack
Old 12-10-2010, 01:47 PM
cbutcher's Avatar
cbutcher
cbutcher is offline
ALBUQ F-1
You might want to try an MG (prince of darkness) wiper motor and set up.
You can set your pivot ( Wheelbox) spacing anywhere by just adjusting the length of your bundy tubing. If you don't want to put MG parts in your truck, just get them from a Ford Pantera same parts just a lot more expensive.
Here is a link to some good advice Stafford Vehicle Components - Windscreen wipers
bobbytnm Not a highjack if I can Help
C
Old 12-10-2010, 02:59 PM
Steve Christensen's Avatar
Steve Christensen
Steve Christensen is offline
Steve Christensen is gaining momentum as a positive member of FTE.Steve Christensen is gaining momentum as a positive member of FTE.
Hi everyone, Craig in the link you posted, that cable drive wiper set up looks to be the same one I bought from a hot rod shop here. I am in the process of fitting it up now, the wiper arms & blades I am using are 10'' Morris Minor I bought at a swap meet a few weeks ago.
Quick Reply: Wiper Arm Pivot Mounting
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
