1994 B3000 2x4 extra cab
Old Dec 30, 2013 | 01:00 PM
  #31
aero993's Avatar
aero993
OK, so I found the second flasher. one is on the back on the fuse block. One flasher has the red wire with a white stripe and a white wire with a red stripe. But I see neither wire in the bundle going to the multifunction switch.
Do you have a part number for the flasher for the hazards?
Old Dec 30, 2013 | 05:28 PM
  #32
87 XLT's Avatar
87 XLT
Any auto parts store can give you the part number
Old Jan 2, 2014 | 07:49 AM
  #33
aero993's Avatar
aero993
After finding the second flasher I begin switching them around. After that doesn't work I try swapping in the a new and switching it around. The next thing I know, the hazards start working. Also, the inside indicator that wasn't working starts to work. I rush down to the inspection stations to have the truck inspected. Before I arrive, the inside indicator stops working. But the hazards and turn signals continue to function. After the inspections I notice the hazards are working but the turn signals aren't. WTH
I'll swap in a new flasher and see if that corrects the problem.
Thanks
Old Jan 2, 2014 | 09:59 AM
  #34
pawpaw's Avatar
pawpaw
OK, good to hear it worked long enough to pass inspection!!!!
If it isn't an acting out flasher, with all the swapping around/plugging/unplugging of the flashers & it suddenly waking up & working, it kinda sounds like a problem around where the flasher plugs into the fuse block. Maybe a corrosion, or wire crimp problem to the fuse block flasher socket contacts. Let us know how your trouble shoot goes.
Old Jan 2, 2014 | 08:24 PM
  #35
aero993's Avatar
aero993
No only one dash indicator lights up.
ducedude
Jan 7, 2014 07:27 AM
cwatson1982
Jul 12, 2012 01:31 AM
ford4604bbl
Mar 21, 2010 01:36 PM
ubereal2
Jan 9, 2007 08:34 PM
96 F150
Electrical Systems/Wiring
May 3, 2003 09:26 PM
