6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Truck just died...Pulled 14 codes!
Old Dec 5, 2013 | 02:19 PM
ecoastkid's Avatar
ecoastkid
I was driving to work this morning and got about 1/4 mile from my house when it suddenly died with a wrench light. And it didn't nicely tell me to pull over first like some people get....it just stalled
After pulling codes, I found 14 of them! (8 unique..6 duplicates)
Normally I search like crazy for an answer, but I'm at a loss as what to search for here...
Here are the codes.
P0101 (twice) Mass or Volume Air Flow A circuit Range/Performance
P0003 (twice) Fuel Volume Regulator Control Circuit Low
P0091 (twice) Fuel Pressure Regulator Control Circuit Low
P179a (twice) Controller Area Network (CAN) Engine Control Module (ECM)/Turbocharger Boost Control A Actuator Circuit Malfunction
P0488 EGR Throttle Control Circuit A Range/Performance
P0670 (twice) Glow Plug Control Module (CPCM) Control Circuit/Open
P0684 (twice) Glow Plug Control Module (GPCM) to Powertrain Control Module (PCM) Communication Circuit Range/Performance
P0691 Fan 1 Control Circuit Low
So far, my thoughts revolve around either a burned or unplugged harness or perhaps a bad PCM or something. I'll get a chance to look at it tonight after I get home from work.
Truck is bone stock and has about 105000 miles. Just got back from a 1200 mile vacation with out issue but I haven't seen the dpf do a cleaning cycle in at least 2K miles. Oil filter and fuel filters changed about 4500 miles ago.
Any thoughts?
Thanks,
Dave
Old Dec 5, 2013 | 03:38 PM
senix's Avatar
senix
I'd be inclined to clear and codes, key on, key off and then check for codes before restart. See what you get.
Old Dec 5, 2013 | 08:53 PM
wp6529's Avatar
wp6529
I'd definitely lean towards a damaged wiring harness, a loose or corroded connector or similar. Those DTCs are too disparate and all point to electrical faults as possible causes. Given that it's now winter the chances of mice nesting on your warm engine and chewing wires are higher as well.
Old Dec 9, 2013 | 08:52 AM
ecoastkid's Avatar
ecoastkid
Looks like its this...
http://www.fordservicecontent.com/pu...sb07-26-02.pdf
Makes me want to kill myself (kidding) because its a cab off repair.
Going to start troubleshooting tonight. Ugh...I've only had this truck for 4 mths and about 4500 miles....for most of the time its had a check engine lights and I finally fixed all that but now this?....I hate this POS. I cant believe I didnt research enough to avoid this.
I think I should have bought a dodge.
Old Dec 9, 2013 | 09:05 AM
ecoastkid's Avatar
ecoastkid
More info...(and it shows some of the additional codes I received)
6.4L Problems - Diesel Power Magazine
FML
Old Dec 9, 2013 | 10:41 AM
senix's Avatar
senix
did you blow the fuse?
Old Dec 9, 2013 | 12:37 PM
ecoastkid's Avatar
ecoastkid
I'll be checking that when I get home tonight. But I'm confident it will be blown. Thats what causes the additional codes.
I have a lift so I can do the fix at home but I really just dont want to be doing this type of job...I'm so angry right now.
I spoke with the diesel tech at a local dealer and he agreed with my quick assesment and thinks its the likely cause. (Of course he suggests I haul it there and pay the 100 for confirmation...I cant blame him for that) He has another one in for the same thing right now. $2500 bucks.
I can't believe that this isnt a recall. I also cant believe that ford would make a fuel pump so inaccessable that you have to remove the cab and the turbos to get to it. Can you possibly do something stupider? He also said much of the hardware that you remove is stainless to you spend alot of time drilling and tapping after it snaps off. He said its a solid 2 day job for an experianced tech.
A piece of info that I think I forgot to include above(for future searchers). My truck was manufactured 4/07 so its def likely to be affected by this.
Old Dec 9, 2013 | 03:28 PM
wp6529's Avatar
wp6529
This is what happens when you shoehorn a medium duty truck engine into a light duty truck (and uprate the HP and TQ from the MDT application as well).
Old Dec 11, 2013 | 06:00 PM
BROWN DOG KTM's Avatar
BROWN DOG KTM
When you say it's bone stock , meaning DPF is still on & NO tuner is being ran ??
Did previous owner run a programmer / performance device ??
Old Dec 11, 2013 | 06:35 PM
ecoastkid's Avatar
ecoastkid
Correct. This truck is stuck down to the paper filter. An old guy on it before me who didn't do things like modifications and tunes lol
Old Dec 11, 2013 | 07:41 PM
BROWN DOG KTM
Only way to buy a used truck
Sorry your having trouble with it tho
Old Dec 13, 2013 | 05:59 PM
ecoastkid's Avatar
ecoastkid
I never updated that fuse 74 is infact blown.
I decided it was worth trying to replace and clear codes to see if I could get it to a dealer and save on towing.
When I went to clear the codes, I couldn't clear 6 of them or the wrench light which I'm hoping one of those 6 triggers.
I thought I read somewhere last week in my frantic googling of something you have to short out to clear the wrench light. Anyone have a clue? I cant seem to reproduce the search that gave me that result.
Thanks
Old Dec 13, 2013 | 06:02 PM
senix's Avatar
senix
sometimes shutting the motor off. Then to just the on position, try to clear then key back off.
sometimes have it idle in park and try to clear and then shut the truck off and then restart.
Old Dec 13, 2013 | 06:44 PM
vloney's Avatar
vloney
If you're more comfortable, you can pull the trans and get access to the pump. When you get a pump, you also need to get the mounting kit. It will have the gasket and the two lines that need to be replaced. Nothing, I repeat, Nothing should snap off. Doing it that way, the turbos dont need to be removed.
RM2738
Oct 29, 2012 12:33 AM
jjames1967
Jan 16, 2010 09:56 AM
61 uni
Dec 6, 2009 05:41 PM
Oil-Pig
Feb 7, 2007 12:01 PM
mongo75
Jan 15, 2007 11:35 AM
