i suspect my rear end my have been swaped
Received 3,172 Likes
on
Yes it is 4wd I belive it it has be swaped or just had the cover changed b/c it has a old rusted chrome pumpkin cover and it seems to be a lot bigger then other 250s I've seen
on
Neither.. that's GM terminology and thankfully we don't have to deal with any of that junk on these trucks. A GM 10bolt is equivalent to a Ford 7.5" which was used on the little 1/4 ton Ranger while the 12 bolt was roughly the same as the 8.8" or 9" found in 1/2 ton Ford trucks. The axle in your F250 is bigger again with a 10.25" ring gear and if your truck is over 8500lb GVWR then it has the full floater 10.25 with a Dana 50 TTB front axle.
on
seeing a chrome or aluminum cover on a rear doesn't indicate there's been a gear change.to find that out,there are many ways (google) such as checking the rpm to speed and comparing it to an online drive train calc.
some people find 10.50 covers in the salve yards/online that come on the late model SD trucks for improved cooling and bolt those on their 10.25's for example.this doesn't mean they swapped gears too.
post up a pic.we'll check it out with ya.
nash22
10-01-2011 11:57 PM
a truck named effy
15
05-27-2009 01:34 PM
aprice
03-30-2005 11:36 PM
