longer window reg shaft
Old Dec 4, 2013 | 04:45 PM
lilrobo's Avatar
lilrobo
has anyone installed longer window reg shaft to clear door panels ??
i just ordered 2 fro mid 50 ,, i saw the instructions and i dont really under stand them
thanks
Old Dec 4, 2013 | 10:18 PM
DGMFORD's Avatar
DGMFORD
I looked at the instructions and they don't make sense to me either. I didn't replace mine with longer shafts but I did have to take apart the regulators to repair a small spring which was broken. I was unable to repair the spring so I ordered new regulators from LMC, they work great a very good purchase, tight and smooth. I will tell you that you have to drill out the three little rivets that hold the cover on, it does not take much drilling, just knock off the rivet heads. carefully remove the old shaft and install the longer one. that part of the repair is easy, repairing that little coiled up spring at the bottom is not easy. the spring was broken and allowing my windows to be rolled down from outside the truck.
Old Dec 5, 2013 | 09:00 AM
Jag Red 54's Avatar
Jag Red 54
I put them on my 54. As I recall there are three rivets on the existing mechanisms that have to be drilled out. You then remove the old studs with the tension springs. Reinstall the new long studs with the tension springs. Put the mechanism back together with three new bolts/nuts to replace the old rivets and your done. Jag
Old Dec 5, 2013 | 09:13 AM
lilrobo's Avatar
lilrobo
Ok great ,, what holds the shaft in ? the gears ?
Thanks, , i got them ordered , i should have changed the crank too in case they are warn, ,
Old Dec 5, 2013 | 10:26 AM
Jag Red 54's Avatar
Jag Red 54
The mechanism has a small "army helmet" looking cap with a hole in the middle of it that holds the shaft in place. There are three rivets that hold the "army helmet in place. Inside the helmet you will find a tension spring that holds the shaft in place so that the window does not roll down by itself as you drive. Mine were broken, but a FTE'er (sorry, I forgot who) sent me two to replace mine. I do not believe that these are available, so if yours are bad, you'll have to rely on the kindness of our members or find old mechanisms at a swap meet next year. Good luck, Jag
Old Dec 5, 2013 | 10:29 AM
lilrobo's Avatar
lilrobo
no mine ant bad , i am getting 1/4 longer hopping that my cranks will clear door panels
thanks
Old Dec 5, 2013 | 01:02 PM
Jag Red 54's Avatar
Jag Red 54
Well, I hope yours are good, but you won't know until you drill out the rivets and look under the "army helmet" cap. Good luck, Jag
Old Dec 9, 2013 | 05:19 PM
lilrobo's Avatar
lilrobo
well got mine apart ,, looks ok so i just need to use small bolts and nuts in place of rivets ? ill lube it good too
thanks
Old Dec 9, 2013 | 07:22 PM
Jag Red 54's Avatar
Jag Red 54
Congratulations! You are now part of an elite super minority that can actually say you have seen the inside of the gear mechanism. Lube with grease and you are ready to reassemble with your three small bolts/nuts. Jag
Old Dec 10, 2013 | 04:53 AM
lilrobo's Avatar
lilrobo
Thanks i hope my window cranks dont rub after all this, ,,
Kecky
Apr 17, 2018 06:43 PM
Skalywag
Jul 12, 2015 08:18 AM
Holmsey
Mar 29, 2009 12:53 PM
hotroddoc
Jun 3, 2006 09:24 PM
Jag Red 54
Sep 8, 2003 09:51 PM
