Window regulator
Old Jul 10, 2015 | 09:09 PM
Skalywag's Avatar
Skalywag
Window regulator
Got my new glass in, finally everything worked out ok with a little tweeking. Painted my inside doors. Started to put my window crank on and the handle shaft is not long enough. The drivers side doesn't stick out far enough to push in the trim and get the pin in. Anyone else ever run into this? As I have said before, everything I do on this truck gives me fits. Truck from hell.
Old Jul 11, 2015 | 06:42 AM
49willard's Avatar
49willard
Not sure that I am reading your problem correctly.
There are 2 different spring loaded trim rings available that you compress to install the pin holding the handle on the square shank. The ones for the deluxe cabs are shorter and compress further to allow for the door trim. I used them on my truck since I have custom door panels. I got mine from Carpenter.
Old Jul 11, 2015 | 09:51 AM
Skalywag's Avatar
Skalywag
Thanks for the response Bill. The handle shaft for the door handle I longer than the shaft for the window crank. Passenger door is fine. looks like someone has installed a regulator from a car or older truck. Everything bolts up correctly and the window operates smooth. Since the machine screws holding the regulator on are so short , the regulator must be installed all the way or the screws wouldn't even start in the holes.
Old Jul 12, 2015 | 08:18 AM
carnut122's Avatar
carnut122
Mid-Fifties sells an extended handle shaft for the 53-56 years. I suspect there is such a part for your truck too?
Ronindog
Feb 18, 2007 04:16 PM
53Merc
Jul 31, 2006 09:06 AM
hotroddoc
Jun 3, 2006 09:24 PM
z 97ford1
1997 - 2003 F150
Oct 21, 2005 01:21 PM
andyjack
Jun 7, 2004 03:21 PM
