jerks in the rain
Old Dec 3, 2013 | 10:30 PM
kellymarianne's Avatar
kellymarianne
jerks in the rain
I tried to explain this to a garage in January with no luck. When it is raining I hit my brakes and my truck jerks like whiplash. Softly hitting brakes doesn't do it, normally hitting them does it (only in the rain), I had some welding done after I went to the garage.... They fixed the front passenger side now it feels like it is under me and it is now doing it when I brake in reverse too... I bought it October 2012 and it was safety inspected until October 2014. Trying to decide if it is worth keeping. I want to keep it but when I go to a garage they see dollar signs.
It only acts up when it's raining.
And I had the welding done in January and it was fine, until I got new tires last week.
Old Dec 3, 2013 | 11:19 PM
Furyus1's Avatar
Furyus1
First question I have is what, on the front passenger side, was welded and why.
When you say "jerking" are you saying it's a sudden neck-cracking jerk that feels like the brakes locked up, or is it more of a pulsing?
Old Dec 3, 2013 | 11:22 PM
kellymarianne
I don't remember. It is all rusted and I got the garage to write everything down and then took to someone cheaper, needed to be reinforced.
Hit brakes it is like whoa whiplash only when it rains and only in parking lots, driveways, etc. going 50 km/h it doesn't act up
Old Dec 3, 2013 | 11:30 PM
Furyus1's Avatar
Furyus1
I'm leaning toward it being something to do with the brakes - I'm just not sure what. Do you have an ABS system on that truck?
Old Dec 3, 2013 | 11:34 PM
kellymarianne
Yeah the ABS light isn't on and it only acts up when it rains. I thought it was fine from January until the new tires last week. So much rain now
Old Dec 3, 2013 | 11:40 PM
Furyus1's Avatar
Furyus1
I'd have another look at that tire installation - whoever did it might have done something while mounting the wheels back on to the truck to cause the jerking to return. Maybe a weld broke?
So much rain now
Yeah, LOL, I'm getting a fair amount of that here, too
Old Dec 4, 2013 | 10:32 AM
Josh S's Avatar
Josh S
Could the tire installer have bent or broken off one of the rotor guards, meaning one rotor is being saturated by rain off the new tire and not 'locking down' as fast as the other side? That might cause the sudden side pull or 'whiplash' you're describing in the rain. Just a thought.
I'm no stranger to extreme rust on my ranger either. No fun at all. My first guess is your core support caved in?
Old Dec 4, 2013 | 06:09 PM
kellymarianne
I read somewhere about moisture in the shoes for these Ford Rangers it was raining again today and was doing it this morning... I usually only drive short distances. Further in the day it was fine. Tonight when I went out I got going and then hit the brakes randomly and it was fine after.
Old Dec 6, 2013 | 07:49 PM
97ranger xlt's Avatar
97ranger xlt
i would take it back to the shop that did the work on the brakes and have them check that right side rotor.. something is not right. even when wet the front discs on my truck won't lock up.. the rears are a different story lol
Old Dec 19, 2013 | 12:05 PM
kellymarianne
Got stuck in snow and when I finally got out, I don't have reverse anymore
Old Jan 1, 2014 | 03:05 PM
7622RM's Avatar
7622RM
I, too, have sticky brakes when first driving my '97 Ranger after wet weather. Within the first couple blocks in my neighborhood, I can actually lock up the rear tires if I press on the brake pedal too hard (speeds under 30 mph). I replaced the brake pads and shoes myself a few years ago. Everything is installed and working correctly. The issue goes away after about 1 mile. My guess is that a light layer of overnight rust on the drums causes excess friction, or the moisture makes the drums grabby. Seems to be a common problem when I google "Ford Ranger grabby brakes".
Grabby brakes in wet weather - Ranger-Forums - The Ultimate Ford Ranger Resource
Old Jan 1, 2014 | 04:24 PM
kellymarianne
I'm calling a junkyard because they said it is transmission and probably too rusted to bother with.
Old Jan 1, 2014 | 08:51 PM
racsan's Avatar
racsan
i know last week we had alot of rain and both vehicles sat a few days (S-blazer & the ranger) when they did get drove again the brakes were really "grabby" on both until the moisture/rust was cleaned off. i wouldnt junk a truck just over a transmission, might just be a band or something simple.
jeffdoerr
2009 - 2014 F150
70
Sep 22, 2011 11:45 PM
b_man360
Aug 25, 2011 11:25 AM
hughes1
Sep 2, 2010 04:08 PM
Ford with onions
Apr 29, 2009 05:46 AM
HillbillyHellcat
Aug 13, 2003 10:45 PM
