no front brakes.
Old Aug 24, 2011 | 08:31 PM
b_man360's Avatar
b_man360
no front brakes.
i have a 1997 mazda b4000, 4x4, 5 speed.
im pretty sure my front brakes are not working. sometimes when i push the peddal it is realy spongey and if i push it a couple times it goes back to normal, but even when it feels normal i am not getting lots of brake power.
if i slam on the brakes they will not lock up and the truck doesnt lean forward like it normaly would on a hard stop.
should i try bleeding them? would the abs be have the brakes stuck off for some reason? anyone els had this problem? thanks.
Old Aug 25, 2011 | 04:31 AM
michigan66's Avatar
michigan66
Have you done anything to the front brakes recently or os this a problem that has developed gradually over time? Your guess about bleeding the brakes would be a good first step. Especially if you have done a lot of off-roading, either the calipers or the pistons are sticking, although, either of thos would result in a stiffer pedal.
Try bleeding the front brakes first and let us know what that does about your problem.
Old Aug 25, 2011 | 04:41 AM
Dan Robertson's Avatar
Dan Robertson
Make sure that the calipers slide pins are well lubricated. (Use special caliper grease)
Old Aug 25, 2011 | 11:25 AM
cj06's Avatar
cj06
check your back brakes and see if they are worn out and or out of adjustment !
Dan Robertson
1997 - 2003 F150
Nov 10, 2014 08:23 PM
devino246
Nov 18, 2011 07:48 PM
IluvDonuts
Jan 31, 2005 12:46 PM
express
Feb 12, 2004 06:44 PM
