Need help with oem part numbers
When I purchased my X the kid that owned it had hacked up the stainless steel fuel lines that go forward from the rail fuel pump just above the oil filter and then again right by the fuel bowl to install a *******ized WVO fuel system.
At the time I simply patched up the lines with 3/8" high quality hose and hose clamps and rocked on. Now I'd like to replace these lines with new oem lines - I know I can get braided SS lines, but would rather just have the diesel side of my engine as OEM as possible.
Any chance that one of you that has access to part # info might be able to help out? The easiest way would most likely be to trace back from the fuel bowl supply and return. I know one assembly drops down from the driver's side of the fuel bowl and is bolted behind the power steering pump. It then connects to a second set of lines which head down the frame rail to the pump and beyond for the return.
Any help in this would be greatly appreciated.
Just dug around using the p/n I got for the steel return lines above and came up with the flex lines too:
F81Z9J338NA - feed and return lines on engine
2C3Z9J338BA - flex lines between engine lines and frame mounted lines
Thanks!
