460 engine issue...
Old Dec 2, 2013 | 06:07 PM
2003pstroke123's Avatar
2003pstroke123
460 engine issue...
Ok first post here in need of help! I have a 1976 ford f250 with a 460 hei distributor it will start fine when cold but once it warms up it starts to miss and sputter then die. And I am unable to start up until engine is cold again..
Old Dec 2, 2013 | 06:17 PM
orangeford's Avatar
orangeford
Sounds like the choke is sticking shut. Check the choke flapper it should open when warm.
Old Dec 2, 2013 | 06:20 PM
2003pstroke123
Got a manual choke its not sticking..
Old Dec 2, 2013 | 06:26 PM
orangeford's Avatar
orangeford
Maybe you have a temperature vacuum switch opening to a vacuum leak when warm.
Old Dec 2, 2013 | 08:12 PM
PA74F250's Avatar
PA74F250
Coil may be taking a dump.
Old Dec 2, 2013 | 09:05 PM
Mr7.50headsup's Avatar
Mr7.50headsup
Its not hard to crank when hot right? Could be too advanced spark. If easy to start and won't run/stay running the other guys advice stays true.
Old Dec 6, 2013 | 01:08 AM
TruckNorris250's Avatar
TruckNorris250
It could be the coil. I had the same problem and I went ahead and replaced coil and regulator just for good measure. Haven't had a problem since!
Old Dec 6, 2013 | 05:37 AM
goodwrench1's Avatar
goodwrench1
I had a coil go bad in June too. I never had one failing before like that but it did and performance declined in a bad way until I replaced it 1200 miles from home in a BAD spot side of town Dallas Texas!
Old Dec 6, 2013 | 06:43 AM
Irelands child's Avatar
Irelands child
Is it actually a TFI distributor with the module on the side or the distributor with the dreaded separate aluminum box on the fender well? Both have heat related failure problems with the separate box being the worst of the two. But with that said, it can be more inexpensively fixed. If it's that one, I can post the repair diagram and parts list.
DieselCamper
19
Aug 25, 2016 01:43 PM
boboh1
Apr 21, 2013 08:45 PM
77bigblock
Oct 12, 2010 05:53 AM
Mestrell
Jul 22, 2004 10:23 AM
edge
Sep 28, 1999 06:25 AM
