Changing Rear Main Seal
Old Dec 2, 2013 | 04:52 PM
Michael Pace's Avatar
Michael Pace
I have a 78 F150 with 351M and auto tranny.
do i need to lift the engine to get the oil pan out?
from what i read some people say yes some people say no. Just want clarification, going to get this done this weekend.
Thanks!
Old Dec 2, 2013 | 05:51 PM
hivoltj's Avatar
hivoltj
2wd = yes
4wd = maybe, maybe not depending on your suspension.
I had a '78 with a 4" lift that had tons of room to change the pan. I think when it was stock suspension it still had room but not sure.
Old Dec 2, 2013 | 06:22 PM
orangeford's Avatar
orangeford
I did it on my truck (79 f150 4x4 4" lift) when I had the 351. Had to lift on the frame a bit to decompress the suspension to get the pan off.
Old Dec 2, 2013 | 07:47 PM
tbear853's Avatar
tbear853
I've had the pan off my '77 F150 4x4 with 351M and swapped in new main and rod shells and rear seal and oil pump and all I did was get the truck up by parking rear wheels on some wheels layed over on sides and raising the front and setting a pair of stout stands under the frame and letting axle drop, and I undid pan hard bar at frame mount only.
I undid one main cap at a time, never did let crank drop in relation to the block, used something to push on plain end of shell and simply slid the old one out and slid new one in above crank. I don't recall a problem with rear main, it may be that I just replaced lower half .... that was 1992.
Jimmyrig
Jan 18, 2013 10:01 AM
Strokin' Ace
Jan 5, 2004 01:51 PM
ksvtwin
Nov 9, 2003 02:07 PM
shawnb
Sep 29, 2001 12:51 AM
tuffguy
Dec 21, 2000 09:10 AM
