Leaky Rear Main Seal
Old Dec 15, 2000 | 08:28 PM
tuffguy's Avatar
tuffguy
Gents,
How hard is it to change just a rear main seal on one of these motors while it is still in the vehicle? Has anyone done it with success? Mine is in a 78 4x4. When I redo the clutch, I want to replace the seal. Mine started leaking right after the rebuild, but it is not bad enough to warrant going in there just for that. Thanks.
Old Dec 18, 2000 | 02:54 AM
fordmando's Avatar
fordmando
Old Dec 19, 2000 | 12:22 AM
400HP794x4's Avatar
400HP794x4
1) remove one end of the trac arm (big bar goes from frame to axle)
2) remove lower shock bolts
3) Jack up truck at least 9" more
now you'll have enough clearance between the oil pan and front axle
4) remove pan
5) remove rear main cap
6) r&r rear main
7) reverse steps
Hope that helps
Old Dec 19, 2000 | 01:53 PM
tuffguy's Avatar
tuffguy
I have a 4 inch lift on the truck and it seems to me that I could easily take the pan off without disconnecting the suspension. Are there any precautions when I put the main bearing cap back on? Thanks.
Old Dec 21, 2000 | 09:10 AM
73Custom's Avatar
73Custom
[font color=red size=3]I have a couple tip that helped me do the rearmain on my 390.
Let the truck set with out running for a few hours before you tear into it, perferably over night, then the oil will drain out of the block - unless you LIKE oil dripping in your face.
When it came to the oil pan gasket, I used weather strip adhesive and glued the gasket to the block, then you don't have the gasket moving around on you.
Don't forget to torque the bearing cap.
Marty[/font]
