I went hiking with the in laws while they snowshoed on the packed trails. Then I fixed the mailbox and replaced burnt out lights outside the garage. If the weather holds up tomorrow, I'm riding the motorcycle.
Well picked the truck up Friday night and I have to say I like it so far. Did the 20-20-20-20 break-in and took her out on the highway to see the difference. 70-80 mph and only 2500-2800 RPM much better than the 3000-3500 before! locker was a little tight at first not letting loose around corners and chirping a bit but after the break-in it is working great. Nice to see both tires break loose going down my road instead of one. Front end is also nice and tight 4 wheel works great.
I guess when they opened the front it did not have 3.73 like the rear. it had closer to a 3.55 ????
Went to my cousins wedding last night with a guest appearance by Sparty partying it up on the dance floor with everybody.
Lazy day (working in the garage might try to install the cameras on the truck and get my antennas mounted back up again.)
