water drip
Old Nov 30, 2013 | 08:31 AM
JAMSRF250's Avatar
JAMSRF250
water drip
I flushed out my coolant yesterday and when I completed the job I now have a drip. It looks like it's coming from a plug located between the inlet and outlet hoses on my water pump. Any idea what this plug is for.
Old Nov 30, 2013 | 08:35 AM
Pikachu's Avatar
Pikachu
If it's coming out of the small hole on the bottom of the pump housing, under the shaft, the shaft seals are shot. Time to replace the pump. I wouldn't wait very long to do it either. If that isn't where it's coming from, post a picture of the leak.
Old Nov 30, 2013 | 03:56 PM
sand_fiend's Avatar
sand_fiend
Yep, sounds like the water pump.. mine just started seeping out of that hole when i replaced it
with the motor off.. LOL..
Grab the fan and see if there is any slight movement at all up or down / side to side.
if it's leaking or has any movement don't wait to replace it or your fan blade may go in to the radiator and cost you a lot more $$
Old Nov 30, 2013 | 04:49 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Let's not jump to conclusions. He said a plug between the inlet and outlet hoses. Try sealing that plug. If the pump is bad it will leak from behind the pulley.
Sent from my Galaxy S4
bluemtn95ford
20
Jan 20, 2014 08:11 AM
bluemtn95ford
Jan 12, 2014 07:39 PM
Bergerson
16
Apr 5, 2009 08:27 PM
floridafordf150
Aug 20, 2002 09:06 AM
Torky
Jun 10, 2000 01:04 PM
