Up pipes question
Old Nov 30, 2013 | 08:15 PM
ReBilld's Avatar
ReBilld
Any time is a good time to switch to bellowed pipes. Even if they are in good shape, you will be eliminating an inevitable leak. It's not a matter of if they will leak, it's usually a matter of when.
Old Nov 30, 2013 | 09:57 PM
fordman67's Avatar
fordman67
I'm curious to see this hole in the cylinder head?!?!
Old Nov 30, 2013 | 10:20 PM
Diesel_Brad's Avatar
Diesel_Brad
Originally Posted by Mowing Man
I bought this truck from a friend of mine with the intentions of going through it this winter. Due to an unexpected engine pull on Smokie, my flatbed, I was forced to register this thing today, and actually drove it for the first time. I heard the leak, and peeked through the wheel well to see a hole in the cylinder head, just above the exhaust port. Looks like a chunk broke/rusted off the head, and then a hole from an exhaust leak developed. So at this point, I'm not sure if I need to do up pipes or not. As soon as I get Smokie up and running again, I'll be pulling the engine in 'Pops' and dealing with it. I'm wondering though, what's the benefit of bellowed up pipes? I'm not asking rhetorically, I'm 100% curious. Is it durability, less likely to leak, or more HP?
Not sure if you are in a RUST area or not but I have seen more than one plow truck ROT a hole in the head(Heat and salt make for a bad combo)
EDIT, sorry for the derail
Old Dec 1, 2013 | 02:57 AM
Mowing Man's Avatar
Mowing Man
Yup, you guessed it. It is a plow truck, so most likely that's what happened. Il try to get a pic or two later on.
Old Dec 1, 2013 | 08:02 AM
arkredneck's Avatar
arkredneck
Bar none diesel offers so bellows for around $400
Old Dec 1, 2013 | 08:58 AM
Diesel_Brad
I was looking at them before I went with the Irate.
IIRC ReBuild does the welding for them.
Another place to look is Rosewood Diesel. He modifies Stock pies to do away with the donuts and adds bellows. I think he said about 1/2 the cost of the Bar None ones
Old Dec 2, 2013 | 05:43 AM
Mowing Man's Avatar
Mowing Man
Thanks guys! I wi be looking into those options in a few weeks. I have the engine out of Smokie, my 01 7.3, as of yesterday, so my 95 is on the back burner for now. I will get done pics if that hole in the head when I get a chance.
rdunagan
Sep 23, 2011 12:10 AM
Gagew90
Apr 9, 2010 09:31 AM
Iron Horseman
General Automotive Discussion
13
Aug 26, 2006 04:18 PM
350pony
Apr 17, 2003 11:09 PM
