Up pipes question
Old Nov 29, 2013 | 08:21 PM
Mowing Man's Avatar
Mowing Man
Up pipes question
Hi guys! I usually hang out over in the 99-03 7.3 section, but I just picked up a 95 7.3 and had a question. I have a huge exhaust leak on this baby, and want to change my pipes out in a while. I'm planning on yanking the engine and going through everything in a few weeks, so I'd do them then. I'm not really excited about the price of up pipes on these older 7.3's and wonder if there's something I can replace them for under $400? Any ideas are appreciated! Thanks.
Old Nov 29, 2013 | 08:41 PM
farmert's Avatar
farmert
Read threw this thread, bill made his own billowed uppies. https://www.ford-trucks.com/forums/1...-up-pipes.html
Old Nov 29, 2013 | 10:27 PM
lindstromjd's Avatar
lindstromjd
Yeah, if you can get through the totally mindless chatter and find the 6-ish posts that are actually useful...
Old Nov 29, 2013 | 10:31 PM
ReBilld's Avatar
ReBilld
...................Mindless????? LOL!
Old Nov 29, 2013 | 11:14 PM
fordman67's Avatar
fordman67
Says the guy asking for help......
Old Nov 29, 2013 | 11:36 PM
ReBilld's Avatar
ReBilld
Oh wait.......you said "totally mindless".....
Old Nov 29, 2013 | 11:38 PM
fordman67's Avatar
fordman67
Hey now....I resemble THAT statement...
Old Nov 29, 2013 | 11:43 PM
ReBilld's Avatar
ReBilld
Apparently we all do LOL!!
Old Nov 30, 2013 | 05:11 AM
Mowing Man's Avatar
Mowing Man
I'm working my way through it guys...
Old Nov 30, 2013 | 07:39 AM
ReBilld's Avatar
ReBilld
Jeb, there are a couple things I do different on those now. I don't use the half of donut gasket anymore, and the on the measurements where you cut the section out for the bellows, cut 3/4" on the bottom, and 3/8" on the top. Only let the pipe go in that end 3/8".
That's all I can say now because anything more could be considered by some as "mindless chatter"....and we don't want that now do we . If you decide to do these and I can help you in any way, just let me know bud
Old Nov 30, 2013 | 07:43 AM
Talyn's Avatar
Talyn
Farfignewton!
Old Nov 30, 2013 | 07:47 AM
ReBilld's Avatar
ReBilld
Originally Posted by Talyn
Farfignewton!
William, I'm pretty sure that could be considered "totally mindless chatter"
Old Nov 30, 2013 | 07:05 PM
Mowing Man's Avatar
Mowing Man
I bought this truck from a friend of mine with the intentions of going through it this winter. Due to an unexpected engine pull on Smokie, my flatbed, I was forced to register this thing today, and actually drove it for the first time. I heard the leak, and peeked through the wheel well to see a hole in the cylinder head, just above the exhaust port. Looks like a chunk broke/rusted off the head, and then a hole from an exhaust leak developed. So at this point, I'm not sure if I need to do up pipes or not. As soon as I get Smokie up and running again, I'll be pulling the engine in 'Pops' and dealing with it. I'm wondering though, what's the benefit of bellowed up pipes? I'm not asking rhetorically, I'm 100% curious. Is it durability, less likely to leak, or more HP?
Old Nov 30, 2013 | 07:11 PM
ReBilld's Avatar
ReBilld
The bellowed up pipes eliminate the donut gasket at the collector. The exhaust leaks between the donut and the pipe, and actually eats away at the pipe. With a solid flange and gasket at the collector, it eliminates that leak, but then you have to have the bellows added to allow the pipes to move since you now have them bolted solid at the collector. With the factory donut gaskets, the pipes could slide in and out a little.
Old Nov 30, 2013 | 07:50 PM
Mowing Man's Avatar
Mowing Man
Ok, that makes sense to me. So when I pull the engine, should I switch to bellows if the pipes are in good shape, or just change the gasket out and call it good? This truck is going to be a backup plow and dump truck for my business and won't be a DD. Thanks guys!
