Where are the Grease points??
Old Jul 15, 2005 | 08:46 AM
DT 466Man's Avatar
DT 466Man
I have new HD ujoints with grease nipples, and the tie rods have nipples on them. The king pins do not.
What all needs to be greased? i'm not sure on this truck.
thanks
DT
Old Jul 15, 2005 | 09:28 AM
84-250's Avatar
84-250
thats all you have to grease. but why dont you have to grease the king pins? when i had my king pins done, the caps on the top and bottom of the king pin had holes drilled and tapped for a grease zerk.
Old Jul 15, 2005 | 09:40 AM
DT 466Man's Avatar
DT 466Man
Mabey mine have a plug. I'll have to look more closely. I might go ahead and put grease fittings in there anyways.
Thanks
DT
Old Jul 15, 2005 | 03:58 PM
84-250's Avatar
84-250
the king pins last much longer when they have grease in them. at 20 years and 130k miles mine needed to be replaced. found out that on one side the bearing had disintegrated and the other side you couldnt move it with a sledge hammer 1/16"
Old Jul 15, 2005 | 04:45 PM
DT 466Man's Avatar
DT 466Man
I'm defenitly going to look into putting some fittings in there.
Thanks
DT
Old Jul 15, 2005 | 07:16 PM
fordborn's Avatar
fordborn
It would be very helpful to get some grease on the king pins. Most I have seen had zerks for them. I have had to try and get some out that had not been greased and that is not a fun job to say the least.
Old Jul 15, 2005 | 07:56 PM
DT 466Man's Avatar
DT 466Man
They are greased, but it is time to hit them with some clean grease, It's been a while.
DT
Streaky
Apr 11, 2014 01:05 PM
obscurity
Aug 26, 2013 09:18 AM
dabaws
Sep 24, 2011 11:50 PM
bmx045
Feb 23, 2007 06:42 PM
