Hr Jr
Old Nov 28, 2013 | 02:16 PM
Harry R Rotz Jr's Avatar
Harry R Rotz Jr
Hr Jr
I own several Ford trucks, F600 LP, 2 F450 all 1990's one F250 ,1984 all Diesel's and a 1984 F150 4.9 gas. I have some other trucks also, the reason I joined here is. I inherited my dad and mothers 1987 F150, 4.9 fuel injected, 3 speed AT. 68000 actual miles. This truck is in good shape, it just has a few issues. One is the dash function cable and the fuel mileage. It seems from what I have read so far I need to take the dash apart and check out this cable. It is still connected just out of adjustment. The truck only gets about 13 miles to the gallon of gas. I think something is out of wack there. I have had a full tune-up and it still is no better. This truck idles fast also. I personally think on long trips I should be able to get 19 to 20 miles / gallon and it should idle slower. Have yet to take it to the Ford garage and have them put the computer on it. Don't really want to pay that bill just yet. Hoping this winter to work on it. The only problem is I don't have a shed to put it in to work on it. Also I am new to these kind of sites so not sure where I am going here.
Old Nov 29, 2013 | 07:59 PM
1984F150SB's Avatar
1984F150SB
First off hello. Secondly welcome. Personally I think 20 mpg may be setting your sights a bit high with my 84 4.9 A/T and never got much better then 16 mpg. The gov site has it listed 14/17 combined at 15. Gives you a start point at any rate .
Old Nov 29, 2013 | 08:20 PM
Harry R Rotz Jr
Hr Jr
I installed high side wall tires on this truck this summer and if I could get 16 mpg high way driving that would be good. With all the tune up work I am lucky to get 13mpg
Old Nov 29, 2013 | 09:40 PM
glruff's Avatar
glruff
FTE Leadership Emeritus
Moved to tech forum
Old Nov 29, 2013 | 10:07 PM
JWC 3's Avatar
JWC 3
Fast idle? Check for a vacuum leak . Pcv hose , etc . A lean mix will cause the computer to add more fuel and effect MPG .
1986F150six
Mar 30, 2016 08:03 AM
peckerwood
6.7L Power Stroke Diesel
19
Oct 24, 2011 04:27 PM
ddrumman2004
2009 - 2014 F150
20
May 9, 2011 08:01 PM
nycsteve
6.4L Power Stroke Diesel
Jan 24, 2009 06:03 PM
flhr
2004 - 2008 F150
25
Apr 10, 2006 07:54 PM
