fuel mileage
Old Oct 23, 2011 | 07:17 PM
peckerwood's Avatar
peckerwood
fuel mileage
is the digital dash mileage indicator accurate? reason i ask is latley its been reading 14mpg..when i bought the truck 3 months ago it was 16-17 mpg and my driving conditions havent changed.
Old Oct 23, 2011 | 07:30 PM
Tom's Avatar
Tom
Welcome to FTE!
It is typically very accurate; mine was normally off by about 3-4% at most. Have your driving habits changed? What about the fuel you buy?
Old Oct 23, 2011 | 07:40 PM
952X4's Avatar
952X4
Mine is very accurate, almost always within .5 mpg or less of hand calculated...Sometimes it's a little high, sometimes a little low...
Old Oct 23, 2011 | 08:08 PM
p12483's Avatar
p12483
does anyone know if the computer takes into account idling time. I hand calculated last tank and computer was off by almost 3 mpg, i did do some idling, prob close to an hour total between remote starts and other things... i am assuming thats why it was so off, and the truck only takes into accout while moving.
Tom Hoffman's Avatar
Tom Hoffman
Get used to that mileage mine now gets 15 and i was 18.2
The dealer said that is normal.
Old Oct 23, 2011 | 08:49 PM
Painted Horse's Avatar
Painted Horse
The refineries started shipping winter grade fuel the 1st of October. Winter grade does not have as many BTUs as summer grade, So you can expect your mileage to drop off until April.
Old Oct 23, 2011 | 09:21 PM
Tom's Avatar
Tom
I'm pretty confident it takes into account all times the injectors are firing. Idling or not.
To test this out, reset your lie-o-meter and drive a short distance. Then sit there and idle and watch. You'll watch it slowly go down!
Old Oct 23, 2011 | 10:27 PM
kper05's Avatar
kper05
Mine is 99.44% accurate from what I've calculated.
As Crazy said, the computer does take into account idle time.
At idle, I use around 0.004 GPM and 1,400 RPM high idle I use around 0.016 GPM.
Old Oct 23, 2011 | 11:14 PM
CascadeF250's Avatar
CascadeF250
My computer mileage is usually within 3/10 of a mile of hand figured. Sometimes it will say more and sometimes it will say less than hand figured mileage. I always thought that it was the variances in fuel nozzels used that effected the milage I received from each fillup.
Old Oct 23, 2011 | 11:18 PM
cummins cowboy's Avatar
cummins cowboy
mine is almost always about .5 mpg high vs actual hand calculated. I would also say since new and now with 21k on the truck my mileage is up prolly about 2.5%
Old Oct 24, 2011 | 08:08 AM
FORDTUF1's Avatar
FORDTUF1
When I first bought mine the first couple to three weeks I actually was babying it, letting it break in a little more and get a few hundred miles on it. I was getting better mileage then as well. Now I drive it like I always drive my vehicles.
I think that most people have that tendency, a brand new $50K-$60K truck usually gets a little easier life the first several weeks. IMHO anyway. Anybody think back to how they treated there's?
Old Oct 24, 2011 | 10:04 AM
OffroadSD's Avatar
OffroadSD
I get about 16.5 combined city and freeway driving, but if I reset the lie-o-meter I get about 18.5 on the freeway driving between 65-70. I live in the Phoenix metropolitan area and take about 2-3 trips per year to Salt Lake City (SLC) and notice that the first 150 miles or so I get about 17 mpg going 75 mp and notice a few regens before the Kingman area, but once I hit the Kingman area I notice the mpg starting to climb and by the time I get to Salt Lake City the lie-o-meter is at 22.5 - 22.8, the speeds from Kingman,AZ to Salt Lake City are anywhere from 75-80 mph. I wonder if the filter gets cleaned out during long drive at high speeds? When I get back to Phoenix my mpg is usually around 17.5 mpg combined driving for the next week and then starts dropping again and usually ends up around the 16.5. The trips to SLC are usually all empty driving. So I am wondering if the dirty filter has anything to do with lower mpg that everyone is seeing?
Old Oct 24, 2011 | 11:04 AM
kper05's Avatar
kper05
I averaged 19.0 (computer) trailer-less this weekend over 250 miles with a mixture of highway, two lane curvy/hilly back roads and several short trips (couldn't avoid it).
To be honest, I was shocked with the high number but I was also never over 67 MPH.
I drive mine harder now than I did when it was new once it's warmed up.
Old Oct 24, 2011 | 01:37 PM
Whiteline's Avatar
Whiteline
It seems strange how much your mileage has changed. The only times I've noticed drop into the 14's is if I'm towing. Otherwise it has been rather consistent over the 56,000 km (35,000 miles) I've driven since getting the truck in April. I guess I haven't been burning winter fuel so that may make a difference this winter...
Old Oct 24, 2011 | 01:52 PM
Painted Horse
Watching the Soot levels on my Edge CTS, I don't see the levels dropping just because I'm driving at freeway speeds. Passive regens need heat. That heat is usually produced by loading the engine, not by increasing the RPM's.
Your EGT temps will be higher at 65 mph fighting a headwind with trailer than at 80 mph with an empty truck.
I'll venture your gains are more affected by the change in elevation. You are climbing from Phoenix, but once in Utah on I-15, you stay pretty much between 4500 and 6500 foot elevation. Also at the higher elevation, Your injectors will lean out the fuel because the air is thinner. Just likethe old carburator days when we used to install smaller jets in the carbs for higher altitude driving.
