Sponsored by: Real Truck
Charging issue
Old Nov 27, 2013 | 11:36 PM
proudtruck's Avatar
proudtruck
Charging issue
wondering if anyone had this issue before for some reason my battery light flickers when im driving regular and on the highway. I have had both batteries checked and they were at 50 percent charge and both were good so therefore I assumed it was my alternator. I removed alternator had it check and it passed all test. Everything was checked at o'reilly and autozone
Old Nov 28, 2013 | 12:17 AM
ATV PRO #11's Avatar
ATV PRO #11
At 50% charge, and a flickering light I would have to assume a short somewhere.
With batteries and alt checking out 100%.
Old Nov 28, 2013 | 06:42 AM
senix's Avatar
senix
Check the connections on the alternator.
Old Nov 28, 2013 | 07:43 AM
madsonp's Avatar
madsonp
I'd say it's the alternator, even though you had it checked, their test aren't always accurate. If there's not enough of a load applied to the alternator when tested it can test good even though its bad.
Old Nov 28, 2013 | 08:48 AM
senix's Avatar
senix
In order to accurately test a alternator you need to pull it and bench test it.
Old Dec 13, 2013 | 10:39 PM
JNG6's Avatar
JNG6
Proudtruck.....Did you solve your flickering battery light issue? I have the same problem. My batteries are good, ground wires seem good but I plan on pulling them and cleaning the connection as soon as I have time to be sure and wires connected to alternator are in good condition and are tight. Have not tested the alternator yet but I have a voltage gauge and it shows the same level whether the battery light is on or not. Even after sitting all night in 20 degree weather it starts like a champ. A short somewhere seems the most likely cause but I have no idea where to even start looking.....
Old Dec 14, 2013 | 12:17 AM
99f350sd's Avatar
99f350sd
The regulator has the circuitry that controls the light...Sometimes it goes bad ..Usually its worn brushes or armature. Regulator and brush kits are cheap on ebay and a snap to put in.
Voltages are supposed to be 12.5 battery fully charged./.14.5 volts engine running.
Dick
Old Dec 20, 2013 | 06:16 PM
JNG6's Avatar
JNG6
Just a little follow up for those that might visit this thread down the road. My intermittent battery light turned out to be the voltage regulator inside the alternator. Although my dash gauge stayed pretty steady (at first anyway) I found that my alternator was putting out between 10 and 13 volts. There was no pattern to how many volts it was putting out. Over a week or two of driving with no issues and strong starts (even in cold weather) the alternator slowly died and left me needing a jump. I replaced the alternator and light has stayed off and I haven't had any other issues. I guess I was lucky to have good batteries that carried me through the low voltage periods when the light came on while driving.
Old Dec 20, 2013 | 06:27 PM
99f350sd's Avatar
99f350sd
Good job thanks for getting back!
command37
Jan 9, 2016 09:36 AM
Dan V
Mar 24, 2015 10:25 PM
flybyu26
Jan 6, 2014 07:44 PM
adam10
Sep 24, 2013 09:52 PM
dogg16
Bronco II
May 19, 2007 10:20 AM
