Bronco II Ford Bronco II
alternator
Old May 17, 2007 | 07:55 AM
dogg16's Avatar
dogg16
alternator
is there a SIMPLE way to check the alternator to see if its bad????
Old May 17, 2007 | 08:04 AM
steve87_gt's Avatar
steve87_gt
You can use a voltmeter and see how much juice its pushing, but that doesnt tell you anything about how the brushes and internals are. You can however take the alternator to a parts store for a full checkup. BUt be ware, if the thing is about to go, the test will finish it off!! I have changed two in the parking lot because of this.
Old May 17, 2007 | 09:25 AM
dogg16's Avatar
dogg16
alternator
how should i hook it up..the red batt is staying on.could it be something else??
Old May 17, 2007 | 03:40 PM
kernel-panic's Avatar
kernel-panic
Read the voltage across your battery terminals with a voltmeter with the engine running. I believe it should be putting out around 13-15 volts, which it still may be close, but not enough amperage -- I can't remember if the idiot light senses one or both of those values.
Old May 18, 2007 | 11:51 AM
rebocardo's Avatar
rebocardo
imo, The only reason the tester finishes off an marginal alt is because it was not done correctly. I have probably tested literally a thousand alternators and/or charging systems and never croaked an alt. that was putting out current.
Make sure the battery is fully charged. Start the vehicle, put on the high beam headlamps and heater system, put it at an 1800 rpm idle. Using remote test leads (so you are not directly under the hood) see if you are getting at least 13.6 if not over 14 volts.
Then shut it off, remove the neg battery cable and put the DMM on it and see if you have a short. If so, remove the alt connector and try again.
Old May 19, 2007 | 08:58 AM
blockheadbob's Avatar
blockheadbob
Alternator:
Back in the old days we used to touch a screwdriver to the rear of the alternator at the center shaft point with the vehicle running and if it was magnetic it was still good. Make sure your screwdriver isnt magnetic before you start.
Bob
Old May 19, 2007 | 10:20 AM
rebocardo's Avatar
rebocardo
I - think back in the old days they used generators, not alternators. I think they (mostly Chevy) stopped using generators in the 60s.
