Outa control....
Old Dec 16, 2013 | 06:01 AM
  #61
real550A's Avatar
real550A
That Jeep looks like the perfect zombie hunter for the apocalypse, Gary.
Too bad that kid showed up. I could use one of those here on the ranch.
Holley 1904 and 1960 model carbs are interchangeable, I think. Outside of being dirty, the accelerator pump is about all that goes wrong with them.
Can't wait to hear that your panel has moved under its' own power!
Old Dec 16, 2013 | 08:32 AM
  #62
GB SISSON's Avatar
GB SISSON
Running and moving are two different things. I'm sure both clutch cylinders are stuck and brakes are non-existent. Those two wouldn't stop me from running around the property, but it still has no driveline since the guy installed the 4 speed. That makes it a roller, but not a driver. Like I said I have a driveshaft from my parts f350 I could use for the front half, and the panel's original shaft for the rear half. Hoping the f350 shaft is bigger dia, then I can telescope the two together with some spacers and weld to perfect length. Otherwise I guess it's a pipe sleeve. I think I have a top rail from my kids old swingset....
Old Dec 16, 2013 | 12:11 PM
  #63
arctic y block's Avatar
arctic y block
Toro Toro!!! Is that the one ya redid? Or another tractor?
I luv yer truck and tractor **** threads Gary, except the
Burger Fingers.
Old Dec 16, 2013 | 12:31 PM
  #64
GB SISSON's Avatar
GB SISSON
That's about as 'redone' as they get here. Looks a bit rough, purrs like a kitten. Speaking of purrrrring. It's alive! Took an hour to find two fine thread nuts for carb studs. Finally found them (7/16?) on the eye bolts for my flareside tailgate chains. Kept the six mis-matched and broken sparkplugs and pumped in some fuel and that's how it went down. Just poured a gallon of antifreeze into the rad, no leaks, now I'm gonna run down and add water. Then I can run it longer. Here's some pics of this morning. And just in time. Danny just drove up!
Old Dec 16, 2013 | 12:43 PM
  #65
real550A's Avatar
real550A
Wow, that is really in pretty good shape! Much better than we'd find around here. No vacuum on the fuel pump...electric wipers too?
Old Dec 16, 2013 | 12:55 PM
  #66
arctic y block
Now that it runs it's okay to buy new plugs. Unless ya some old ones around
that will work in her. Ya gonna put a diesel in anyway? Right?
Old Dec 16, 2013 | 04:15 PM
  #67
GB SISSON's Avatar
GB SISSON
I was thinking the same thing.... It's ok to put the new plugs in now. When you are driving with no clutch or brakes, it's good to know all the spark plug wires will stay on. So, I never realized the 1/2 tons also have a 2 piece driveshaft with center carrier bearing..... Sooooo... the PO put in a 4 spd where there once was a 3 speed. It looks like the front shaft is about 1 1/2 or so too short. I gather that perhaps the 4 spd is shorter overall than the 3 spd? Looks like I can use the original rear shaft from the panel and shorten the front one from one from my f350? This could sound really horrendous to some of you, but I think I'm gonna turn a piece of oak on my wood lathe so it's a nice pound in fit into the two cut halves of the front driveshaft, and then either weld around the perimeter, or put a sleeve on the outside and weld that on. Once again, the worst that can happen is the weld breaks one day and the two 'half shafts' turn independently of each other and I'm stuck beside the road. I might get lucky and find a piece of pipe that's a good fit inside or outside. Either way, I gotta drive this thing. I will post up photos next, forgot to download them before typing......
Old Dec 16, 2013 | 04:29 PM
  #68
GB SISSON's Avatar
GB SISSON
New pics.....and one for arctic y block so he can actually enjoy his meatloaf tonight (yes, I wash my hands before dinner)........
Old Dec 16, 2013 | 05:19 PM
  #69
spurredon's Avatar
spurredon
So, is the wheel base about the same as a long bed?
Old Dec 16, 2013 | 05:33 PM
  #70
arctic y block
That healed nice. Wish our trucks would heal thy selves like we do.
Mechanics get payed almost as much as Doctors now so they should.
Let me know when the new wears off on the panel so I can come
drive her home.
Ya new plugs would work for that. "Don't need brakes as they just slow
ya down".
Old Dec 16, 2013 | 05:36 PM
  #71
spurredon's Avatar
spurredon
drive her home.
ya down".
I was wondering what they were for!
Old Dec 16, 2013 | 06:01 PM
  #72
theodore/teddy's Avatar
theodore/teddy
Refyred
Gary that panel looks real nice! Good to see it runs.
Old Dec 16, 2013 | 06:30 PM
  #73
hiball3985's Avatar
hiball3985
Panels have a 110" wheel base, I think that is the same as a short bed?
Old Dec 16, 2013 | 06:36 PM
  #74
GB SISSON's Avatar
GB SISSON
Danny left early just like he came late. He brought me a bottle of wine from the local mom and pop store. All I can sAY IS THE PANEL RUNS REALLY, REALLY SWEET. OOPS CAP LOCK. It sounds like a sewing machine..... If you want a a really good bed-time story/song....... just look at the 48-56 site and see my song. I think I'm gonna regret this....
Old Dec 16, 2013 | 06:56 PM
  #75
GB SISSON's Avatar
GB SISSON
I have been writing these lyrics for a few years. My wife and I drove East of the mountains last weekend and she finally wrote them down for me. I have owned many old ford trucks throughout the years and the split rims and cloth covered wires seemed to fit in the older trucks, which I have owned many of.....
