Camshaft Position Sensor
Old Jun 23, 2003 | 12:10 PM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
Anyone ever replaced a camshaft position sensor? My '94 PSD wants one, and I'd love to give it one, just unsure of where it is, how difficult it is.
Old Jun 23, 2003 | 12:49 PM
johnsdiesel's Avatar
johnsdiesel
It's on the front of the engine block at about 10 o'clock. You need to pull the number 9 fuse under the hood, disconnect the cable from the sensor, and remove the 10mm bolt. I would suggest you buy the new part from International because they tend to be about half the price of Ford. International calls it a "CAMP sensor" and Ford calls it a "CMP sensor". When you put the new sensor in place, make sure to coat the new seal with either oil or vaseline. BE VERY CAREFUL not to round the bolt. It's in a tough location and is on there real tight. Also, be sure to get the correct part. There are 2 sensors that are used, and your engine uses the older style.
Here are the International part #'s for the sensor:
Engine Serial # 375548 and below is part # 1821720C99
Engine Serial # 375549 and up is part # 1825899C93
Old Jun 23, 2003 | 12:52 PM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
Thanks a lot!! And I was planning on going to International, it's where I get all my parts. You are correct. Usually about 1/2 price. Again, THANKS!
Old Jun 24, 2003 | 12:15 AM
Jerrybo66's Avatar
Jerrybo66
Question for Johndiesel...
The opinion I get from the many posts on this subject, it seems like this sensor is a weak spot on the PSD and most of the failures occur from '99 and newer. "97 and older doesn't seem to have that frequent of a problem, but is it often enough that you would advise carrying a spare in the clove box... Thank ya' much..
Old Jun 24, 2003 | 12:34 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The CMP is probably the most common failure. I carry a spare on the premise that if I have it, I'll never need it.
Old Jun 24, 2003 | 08:46 AM
johnsdiesel
I don't carry a spare CMP sensor, but a lot of guys do. When your sensor starts to go, replace it and keep the questionable one for emergencies.
Old Jul 12, 2003 | 05:42 PM
MrFeexit's Avatar
MrFeexit
can anyone post a picture of the location of the sensor?
bluegrassford
1997 - 2003 F150
Oct 22, 2010 02:44 PM
loudford
Nov 12, 2009 06:25 AM
bigmem124
Mar 29, 2009 08:53 AM
mycam8u2
Jun 24, 2006 09:03 AM
96ford4x4turbodiesel
19
Jun 20, 2004 01:15 PM
