computer box under seat?
Old Nov 24, 2013 | 11:44 AM
dazedandconfused's Avatar
dazedandconfused
Okay guys I'm working on restoring a 1983 F-250 4x4. The truck is a XLT with all options and was originally a 351, 4 speed. My question is what does the computer box under the driver side seat control?
Old Nov 24, 2013 | 12:11 PM
Rogue_Wulff's Avatar
Rogue_Wulff
I believe that box was used on certain 351W's, with DS3 (IIRC) ignition systems.
Old Nov 24, 2013 | 12:30 PM
dazedandconfused
I was thinking it had something to do with ignition. I believe it might even say ignition on one part of the plug. I'm trying to figure out if it worked anything else like cruise control.
Old Nov 24, 2013 | 12:39 PM
ctubutis's Avatar
ctubutis
The EEC boxes control operation of the engine only and nothing more.
Old Nov 24, 2013 | 12:59 PM
dazedandconfused
Good deal that's what I was thinking. All the wires are cut under the cab so I'll just remove it if it won't interfier with any other operations.
Old Nov 24, 2013 | 02:33 PM
Gary Lewis's Avatar
Gary Lewis
If the 83 is like 49-state 82's the wiring for the computer was completely separate from the other wiring. And, the computer had its own sensors and relays. So all that can be taken out w/o effecting the rest of the engine's wiring. Anything the computer wires to, like the relays on the valve covers, the timing sensor on the crank, its own temp and oil pressure sensors, and manifold pressure sensor can be removed as well as the associated wiring.
Old Nov 24, 2013 | 02:38 PM
dazedandconfused
Thanks for the help everyone. I'll just delete it then since I'm going with a different engine.
Ant1
Aug 30, 2010 05:01 PM
HENDEL JR
Jan 7, 2006 10:51 AM
ET1
1997 - 2003 F150
Dec 15, 2004 04:10 PM
jeepkiller
Oct 28, 2004 05:51 PM
