17 inch wheels on 2003?
they'll fit, but rub
99-04 models have narrow axles
05-14 models have wider axles
to run 05+ rims on a 99-04 model, you have to use 2" thick spacers on front and rear axles.
some 04 models had 18" rims, those will work with your 2003 without spacers. otherwise, factor in the cost of spacers when you purchase a 2005+ set of rims. good spacers will run you $500-800 easy
