Wheels Difference
Old Apr 6, 2007 | 11:11 PM
Murk's Avatar
Murk
Wheels Difference
My '04 FX4 Scab came with 17" rims. According to Tire Rack, original tire size is 255/70-17.
Orignal for the 18" rims is 275/65-18.
I'm just curious if there's any major difference done to a truck that has 17" wheels as opposed to the optional 18" wheels? I mean are they completely interchangeable? I would like to upgrade to the 18's.
Old Apr 6, 2007 | 11:21 PM
last5oh_302's Avatar
last5oh_302
The 17 inch has a 31 inch diameter and the 18 inch has a 32 inch diameter. There would be a small difference in the speedometer reading but nothing worth worrying about.
Punch both sizes into this calculator and check out the results:
http://www.discounttire.com/dtcs/infoTireMath.dos
Old Apr 7, 2007 | 02:26 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
go for it. since both are OEM, you WILL NOT have problems with them
as said though, you might see about 1 mph difference if you get the 18" rims. they are 31.8" tall, vs the 31" tall tires.
Old Apr 7, 2007 | 06:15 AM
Murk's Avatar
Murk
Awesome guys, thanks!
Old Apr 11, 2007 | 11:13 AM
Carguy1959's Avatar
Carguy1959
I have a 04 FX4 SCAB. It came with 17"s. The trucks with 17"s have 3.55 gears the trucks with 18"s have 3.73 gears. I put 18"s on my truck. I had my mph checked it was off by 3 mph at 70.....
Old Apr 11, 2007 | 11:48 AM
sammer4u's Avatar
sammer4u
I have 17's on mine with 3.73
Old Apr 11, 2007 | 12:09 PM
BruceFX4's Avatar
BruceFX4
My 04 FX4 also came with 17s and 3.73s. Tire size had nothing to do with gear choice, at least in 04 and 05.
Old Apr 11, 2007 | 05:17 PM
last5oh_302
Yep, my 05 XLT has 17's and 373's, but the 373's are something that comes along with the trailer tow package from my understanding.
Old Apr 11, 2007 | 09:13 PM
Murk's Avatar
Murk
I never really dug too deep to see what gearing my truck had. I do have the tow package, is there a tag on the diff or a stamp or something I can use to verify?
Again a n00b question I'm sure. I think I remember some of the older cars having aluminum tags stamped with the original gearing on it.
Old Apr 11, 2007 | 09:36 PM
last5oh_302
To the best of my recollection, under "axle code" as indicated on the door sticker, if you have a "B6" code, you have 373's.
Also, at 120 kmh, or roughly 75 mph, your tachometer should be reading close to 2200 rpm.
Old Apr 12, 2007 | 05:39 AM
last5oh_302
Correction. At 120 km's per hour (75 mph) the tach was reading 2050 rpm.
Old Apr 12, 2007 | 05:53 AM
HomerWinzlow's Avatar
HomerWinzlow
Mine has 3.55 and trailer tow package.... came with 235/75 17s and I changed to 265/60 18s. I recalibrated odometer.
Old Apr 12, 2007 | 06:35 AM
last5oh_302
Do you have the 5.4 Homer? I forget some of the info about your truck in previous posts, however I do read everything you have to say .
I'm thinking perhaps that with the 5.4 and trailer tow package, the truck comes with 373's? I'm certain I heard or was told this somewhere. Could be wrong though. Wouldn't be the first time.
Old Apr 12, 2007 | 06:57 AM
HomerWinzlow
That may be a requirement for the 5.4. I have a 4.6. Or 5.4 may be a requirement for 3.73. You know how Ford loves to make you buy a different package to upgrade one item.
Old Apr 12, 2007 | 04:48 PM
Murk's Avatar
Murk
Well, I checked my sticker and my axle code is H9, which from what I can find, means it's a LS 3.55 diff. I have the tow package on my FX4 with 17's, so it's not an automatic 3.73's for the tow package.
In a way I'm glad they are the 3.55's. I read somewhere else that if you do a minimal gear upgrade of .25, that the gain is minimal for all the effort and cost. Now that i know I have 3.55's, moving up to the 4.10's would be a nice jump. Although that will happen quite a ways down the line.
My main focus now is getting the 18's and a bigger tire to make it just look fatter and meaner. I would like to go a little bigger than the stock 18 size, but not too much. It won't have THAT much of an effect on the rear would it?
