1978 - 1996 Big Bronco
Heater vents control problems
Old Nov 22, 2013 | 04:21 PM
garydmundy's Avatar
garydmundy
Hi, I have a 1994 bronco but it is not stock. It has a stroked 351 (405 cu in), and a Holly carb. There is absolutely nothing computer controlled any more. My problem however is the HVAC vent controls. My controls work when you put it on defrost and floor but when you put it on mix, nothing happens. Did search on this forum and found an actuator under hood and one under the dash. The under hood works fine but the one under the dash (center, right under control panels) doesn't work. If I move it manually, it opens the (mix doors). There is a blue vacuums hose attached to it, and it doesn't seem to have any vacuum. Where do I go from here? Where does this blue vacuum hose get its vacuum from?
Thanks ahed of time.
Old Nov 24, 2013 | 11:16 AM
Encho's Avatar
Encho
The Southernmost Mod
I didn't see this before, but you're right, the door is vacuum activated, you need to search for any disconnected lines behin the dash and in the engine bay, near the A/C blower.
Old Nov 24, 2013 | 12:18 PM
garydmundy's Avatar
garydmundy
Thanks, will try to find the "other end" of the vacuum line.
Old Nov 24, 2013 | 02:46 PM
gatorfor88's Avatar
gatorfor88
I believe the other end of your hose is attached to the hvac controls on the dash. If I recall correctly from working on a crown vic it gets its vaccum from a canister under hood.
longmire56
1997 - 2003 F150
Oct 30, 2015 10:06 PM
Timberline
Jul 24, 2007 07:32 AM
bobbyredondo
Aerostar
Nov 25, 2005 08:59 PM
RDK
Jan 9, 2005 05:34 PM
rc62
Feb 5, 2003 07:13 AM
