Sponsored by: Auxito
ac vent issues?
Old Oct 30, 2015 | 02:30 PM
longmire56's Avatar
longmire56
ac vent issues?
for some reason the air no longer comes out the panel vents either on auto or manual. is there a fuse that tells the ac which vent to open when you press that button or is there maybe a flap that is just stuck open? right now the air appears to be coming mainly out the defrost vents with a little coming out thru the floor.
Old Oct 30, 2015 | 08:17 PM
steve(ill)'s Avatar
steve(ill)
there are 3-4 different vacuum cylinders that move doors to direct the air.. They are all controlled by vacuum hose from the engine to the **** on the dash. The **** directs the vacuum to a given cylinder. If you loose vacuum, the doors close and the air comes out the defrost only... You have lost vacuum. Either the hose from the engine compartment, thru the firewall ,between the glove box and center line of truck ....... or the switch on the dash is leaking past the seals and loosing vacuum to the other ports. Check under the hood and look for a loose / broken/ failed hose at the firewall.... If OK, check the vacuum on the hose into the control **** behind the dash.
Old Oct 30, 2015 | 08:18 PM
steve(ill)'s Avatar
steve(ill)
follow this link to get a vacuum - door schematic.
https://www.ford-trucks.com/forums/1...and-panel.html
Old Oct 30, 2015 | 10:06 PM
projectSHO89's Avatar
projectSHO89
Follow the link in my signature to the HVAC FAQs.
1999-F150
1997 - 2003 F150
Jul 10, 2017 08:42 PM
02GrayPowerStroke
1997 - 2003 F150
Jul 28, 2015 07:37 PM
Mr Dave73
1997 - 2003 F150
Nov 27, 2010 01:41 PM
af4ms
Aug 3, 2007 08:41 AM
MSG
1983 - 2012 Ranger & B-Series
May 12, 2003 07:30 PM
