1977 Frame
Old Nov 20, 2013 | 05:55 PM
darren_palms's Avatar
darren_palms
1977 Frame
I found a 1977 3/4 ton 4wd high boy for $500 and I was wondering if my 1978 3/4 camper special body will fit on the high boy frame?
Old Nov 20, 2013 | 08:41 PM
darren_palms
2wd Power steering
I was also wondering if the power steering from my 1978 camper special would work for a 1977 3/4 ton 4wd?
Old Nov 20, 2013 | 09:06 PM
Dave145's Avatar
Dave145
Frames are different between a highboy and camper special truck I think
Old Nov 20, 2013 | 09:35 PM
ShaneNP123's Avatar
ShaneNP123
Camper Special has nothing to do with it, just the Highboys had narrower frames, divorced T-cases and low-pinion, closed knuckle front axles. The Highboys also had a
ram-assist type power steering system which is next to impossible to get parts for.
It has been done, but dont expect it to be a bolt on affair, body mounts will need to be modified. If you want to run the newer style steering you will have to modify the frame to mount the steering box, which is what most guys do when upgrading the power steering to the post Highboy steering setup.
Old Nov 20, 2013 | 09:37 PM
fordrealdrive's Avatar
fordrealdrive
I'm guessing you are wanting to make your 2wd a 4wd? If your '78 has 133" wheelbase the swap is fairly direct. The 2wd cabs have the rear cab mounts inboard of the frame on a cross member and the 4wd's are mounted outboard of frame on brackets that are riveted. Your options here are to either re drill the cab for the outboard mounts or modify the highboy transfer case X-member to accept cab mount bushings. If you're NOT using a body lift, and NOT using the truck for extreme offroad adventures, I would drill the cab for the outboard mounts.
The next obstacle is the bed...The highboys have a narrower frame from the cab back (34") much like the cab/chassis and super camper/trailer special trucks. You'll need to re drill the bed holes or modify the frame to mount the bed.
Also, you'll need to address the gas tank issue....your chassis mounted tank will not work in the highboy chassis....The highboys had incab tanks.
As for the steering, there are several threads here covering that topic. The most common approach is to swap the steer system from a 77.5-79 F250/79F350 4x4. This requires metal fabrication and should be done by competent individual.
Old Nov 20, 2013 | 09:50 PM
darren_palms
I knew mine had the mounted gas tanks but those won't fit between the highboy frame?
Old Nov 21, 2013 | 10:51 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
No your (rear 77) between frame gas tank will not fit the highboy frame.
Old Nov 21, 2013 | 08:34 PM
darren_palms
1978 3/4 Camper special
I've heard the 1977 highboy has a narrower frame but my 1978 3/4 camper special has a 34" frame what is the width of the 1977 3/4 highboy? This is the frame I want to put my camper special body on….
Old Nov 21, 2013 | 10:25 PM
fordrealdrive
What is the wheelbase of your "78 camper special" ? If you have a 34" Wide frame....I'm betting you have a 140" WB .
Not trying to be rude but your questions have already been answered...
Old Nov 21, 2013 | 11:16 PM
darren_palms
It has a 133" WB...I thought only the super camper specials had 140"WB so the could fit in a spare tire in the side of the bed in front of the rear tire.
nitro520
Oct 21, 2006 05:10 PM
77f2504by4
Jul 16, 2006 12:32 AM
sunnyb
Jan 18, 2006 06:20 PM
tude
Apr 27, 2004 06:25 PM
mlf72f250
Oct 8, 2002 12:23 AM
