hi im new on here and have acouple questions.ive gotta 96 f150 xlt with a 302 and auto.it pings real bad goin up hill especially when you get on it.91 octane its not as bad but 87 octane its real bad.its got 220,000 miles on it.any one know what I can do to make it quiet
Agreed, guys Might even also try premium gasoline with 93 octane that is what i use in all my stuff including small engines. also use seafoam on occaision.
Yeah I have run 87 octane from time to time but it still our 87 octane fuel now a days is junk I think. I wish we still had leaded gasoline like in the old days.
Have you pulled the codes from the ECU? That may help in figuring out a problem. The EGR system may not be operational and that can cause engine ping too.
Verify ignition timing and pull codes to see what the ECU is telling. Correct those issues if any then clean out the engine with seafoam.
