driveline movement
Old Nov 18, 2013 | 01:30 PM
bra$$monkey's Avatar
bra$$monkey
driveline movement
Hi,
56 F100
351c
c4
jag rear
not sure the front - S10 or Mustang 2
Issue - when I really stomp on the gas the engine & transmission move forward so far they actually pull the shifter into 2nd gear.
I got the water pump to touch the fan.
when I look visually everything looks fine - the trans mount is brand new - could a motor mount be broken? How could I tell?
Old Nov 18, 2013 | 03:14 PM
AXracer's Avatar
AXracer
I've seen plenty of engines that rock side to side, but never one that moved fore and aft, especially with an IRS. There is definitely something wrong, my money is on broken or disconnected motor mounts. Easiest way to tell, besides watching where it's moving while you goose the throttle, would be to put a piece of 2x8 under the oil pan sump on top a floor jack and jack up on the engine. It should be pretty obvious what's wrong when the engine lifts off the mount(s).
Old Nov 18, 2013 | 03:29 PM
bra$$monkey
will jacking on the oil pan hurt it at all?
CharlieLed's Avatar
CharlieLed
Check the end play on the driveshaft yolk, if the differential is torquing then it may be pushing the driveshaft forward...without the proper end play then there is only one way the the trans/engine can be pushed.
Old Nov 18, 2013 | 03:34 PM
bra$$monkey
when i bought it - they had literally just installed the transmission. they guy said he was going to go under & make sure everything was tightened up.
I wonder if they didn't bolt down the engine? ha that would suck.
Old Nov 18, 2013 | 03:36 PM
bra$$monkey
good idea - I have a u-joint going out - I get a clunk - the truck only has 5k miles since being built - it could be this is putting pressure on the joint causing premature failure - the drive shaft would have to have been custom made.
I'll try jacking it up first & the shaft play second.
Old Nov 18, 2013 | 03:45 PM
bra$$monkey
I do not have this issue when doing burn outs - if the truck does not lurch forward the problem is not there.
So it is definately moving when under load - it has to be either the motor mounts are not bolted down or the drive shaft is a hair too long.
Old Nov 18, 2013 | 03:53 PM
wallster's Avatar
wallster
When the PO installed the driveshaft he may have measured it incorrectly. With the vehicle sitting on the ground (don't jack it up, just take a peek under the truck) there should be about an inch and a half of the transmission yoke sticking out of the transmission (it needs to work like like a slip joint). If it's too close, when you "get on it" it could be making the rear suspension depress and if the driveshaft is banging into the transmission everything would be jolted forward. If your truck is too low to get a good look, you will have to jack it up and rest the rear axle on jackstands and set the front frame rails on jackstands as well (so there's sprung weight on the rear suspension).
Just a thought.
Wally
Old Nov 18, 2013 | 04:22 PM
bra$$monkey
the rear suspension sinks significantly when I get on it. The jag rear end has 4 springs & 4 shocks - but it sinks a good 4 or 5 inches when i drop the hammer.
I've been meaning to replace the 4 shocks with a set of air shocks to help keep the rear in place.
hmmmm - I think we are narrowing it down.
Old Nov 18, 2013 | 04:24 PM
bra$$monkey
so if the yolk is too long - can I just cut it down? Its not like a 4x4 where I'll get extreme axel droop from jumping or crawling over rocks.
But I blast around like I'm in my own personal rocket all the time.
Old Nov 18, 2013 | 04:43 PM
Gicknordon's Avatar
Gicknordon
If it has irs the rear squat shouldnt change the distance between the tranny and rear end.
Old Nov 18, 2013 | 04:54 PM
bra$$monkey
hadn't thought about that - I'll give it a look tonight & maybe post some pics.
Old Nov 18, 2013 | 05:44 PM
wallster's Avatar
wallster
You would need a shorter drive shaft (and maybe a longer yoke) since it has to have enough travel in and out of your transmission based on how much the rear suspension travels.
Wally
Old Nov 18, 2013 | 05:47 PM
wallster's Avatar
wallster
That's true, I didn't realize he has independent rear suspension. The differential would theoretically stay at the same position. Posting some photos might help solve the mystery.
Wally
Old Nov 18, 2013 | 05:57 PM
The Horvaths's Avatar
The Horvaths
You may want to be a little cautious about how much torque you subject that Jaguar rear end to. When they hook up well, they can pretty much be torn right out of the vehicle.
I had an '86 XJ6 with a SBC 350.
BTW: my buddy who bought it is finally selling the body/chassis. It's in the Dallas area. If somebody wants it, PM me.
