The rear end squat on hard launches is a design characteristic of the Jag IRS. It was designed for high speed cornering, not drag racing. If your intent is/was to do drag launches this was the wrong rear suspension choice, you would have been better served by a solid axle with 4 link, or ladder bars.
My cousin had a 70 f100 that would shell a rear u joint everytime he nailed it.After much frustration,we pulled the rear springs..They were so worn they would flatten completely just by standing on them.New springs solved the problem.
Probably not,just throwing that out there,i never would of thought tbat it could have been the problem with his,but sometimes we got to think outside of the normal.A loose crossmember may be your gremlin.Good luck on finding it.
A lot of the suggestions being thrown around keep missing the fact that Brassmonkey is running a JAG IRS not a solid axle or leaf springs. Changing the coilovers would just make the ride harsher not make the geometry behave any differently. The Jag IRS is not designed for drag launches, the geometry makes it squat.
BM, you shouldn't be using IFS, IRS with out sway bars! Put the SJ6/12 stock sway bar on the rear and a front bar the diameter of the Jag front that fits on the front. But sway bars alone won't stop body roll. That's the function of the shocks entering and exiting a corner, the sway bar doesn't affect the roll until mid corner.
The truck is always going to have a lot of roll, both actual and perceived. Actual because by nature it has a high roll center, and perceived because you are sitting higher than that roll center, like sitting on an upper deck of a boat in a rough sea it will feel like you are rolling more than if you were sitting low.
Just a question and comment. Did the fan contact radiator high or low? If it is the trans. mount I would expect it to contact high.
Good luck in your quest
AxeRacer has a clue as to what he's talking about.
And, unless you want serious repair bills, you shouldn't ever try to "launch" with that rear end.
