driveline movement
Old Nov 19, 2013 | 07:26 PM
  #46
bra$$monkey's Avatar
bra$$monkey
I'm really going to miss doing burn outs too. But I guess I'm not 16 & should drive like an adult too.
Old Nov 19, 2013 | 07:28 PM
  #47
bra$$monkey
The water pump pull just kissed the electric fan. Top or bottom is relative to where it's mounted.
I think that issue was more my rad moving than the eng.
Old Nov 19, 2013 | 07:45 PM
  #48
Moe Craig's Avatar
Moe Craig
I apologies if it sounded like I was saying that sway bars wouldn't help for this scenario, it will. And as stated above shocks are used to control body roll, but they control body roll by controlling the speed of spring (coil or leaf) motion. Sway bars controlling the left and right sides of the axles by a spring load under pressure from lateral force. Yes, changing springs can make a stiffer ride and probably will. Yes, we have been talking about a truck that aren't aerodynamic and with a high center of gravity, so prone to body roll. We must remember that not just one part of a suspension system is a stand-alone instant cure for all problems, not even a sway bar. Please correct me if I'm wrong!
Old Nov 19, 2013 | 07:51 PM
  #49
bra$$monkey
Very good points.
I have a good list of things to improve.
I'll get to the springs & sway bar. But I need to fix the motion in the trans first.
All good advice tho. Keep the ideas coming.
Old Nov 19, 2013 | 08:15 PM
  #50
Moe Craig's Avatar
Moe Craig
Originally Posted by bra$$monkey
Very good points.
Sorry for before getting off subject.
How about driveshaft length? Driveshaft balance? Check rear transmission bearing, movement of driveshaft at transmission? How much HP does the motor have? Are your mounts rubber or polyurethane mount?
Old Nov 19, 2013 | 08:51 PM
  #51
Project-55's Avatar
Project-55
Wow, Just spent some time going back and forth, reading and re-reading this thread,,,,and my head hurts.
Here are my feeling on the subject:
With an IRS, any IRS, the diff will not/can not, move unless their rubber isolators are shot, so there is no way the diff can Push the driveshaft forward, thus pushing the tranny/engine forward into the radiator. However, if the isolators on your Jag IRS are shot they could torque about 1/2 inch forward under heavy load but it sounds like you have a lot more movement than that.
If the tranny cross member is loose or the tranny mount is shot it would give you a side to side shudder, almost like wheel hop but not a forward movement of the entire drivetrain and surely not enough movement to drop the tranny into a lower gear during "pedal to floor" operations.
So, in my opinion you have bad engine mounts, either the mounts are bad, the hard-points to the frame are improperly gusseted, or maybe just loose mount bolts.
Take some time and look Very closely at your entire engine mount installation, the block mounts, the mounts themselves, and the frame mounts.
My guess is that if you motor is moving as much as you say, it's an engine mount problem.
Gary
Old Nov 19, 2013 | 11:47 PM
  #52
Daddyo's garage's Avatar
Daddyo's garage
Ok. If the engine isn't moving. I'll bet the body is shifting! That would explain the shifter moving and the radiator moving towards the water pump. This seemed obvious to me on page one. Engines don't move forward at launch, but the body will shift if it isn't secured correctly!
Old Nov 19, 2013 | 11:57 PM
  #53
bra$$monkey
Body shift. I hadn't thought of that.
Old Nov 20, 2013 | 05:54 AM
  #54
jimcar-9's Avatar
jimcar-9
Gary
Are you sure There are any rubbet Mount?
Old Nov 20, 2013 | 06:38 AM
  #55
bra$$monkey
No rubber in the rear end mount. It's up there tight.
I jacked the truck up under the oil pan & the engine didn't move. The mounts look good.
I can't get anywhere near the tranny. The running boards are 6 inches off the floor so I can't tell if the X member is loose. The tranny is mounted tight to the X member though.
Old Nov 20, 2013 | 06:54 AM
  #56
jimcar-9's Avatar
jimcar-9
Wild thaught? You dont have problem with the transmission? Kickdown? What lead you into movement & linkage problems?
Old Nov 20, 2013 | 07:46 AM
  #57
bra$$monkey
Ugh. I think I'd rather have movement problems.
The truck physically shifts the column shifter into 2nd gear & when I'm hard on it I can't shift back into dr. As soon as I let off the gas I can easily put it back in D
Old Nov 20, 2013 | 07:50 AM
  #58
jimcar-9's Avatar
jimcar-9
I just say.... That it doesnt haveto be movement, it might be something else. Or movement?
Old Nov 20, 2013 | 08:30 AM
  #59
49f3dls's Avatar
49f3dls
I had a bad gear (chipped tooth or teeth) in 4 speed that would shift from 1st to 2nd when I launch it -- didn't need the clutch at all it just did it at the right rev's. If I kept a little pressure on the shifter it would stay in 1st. This was in an Austin Healey with a built up FORD 289 and a 4 speed with the original AH rearend. I've never heard of this in an automatic but maybe it's a possibility.
Old Nov 20, 2013 | 10:37 AM
  #60
The Horvaths's Avatar
The Horvaths
Body shift was the first thing to cross my mind as well. Do you hear the mount areas rattle? Have a friend check the gap between the bed and cab if that's possible. See if it closes upon acceleration.
That could potentially be dangerous in a sudden stop or impact. You are in the cab.
Also, if I understand correctly, your vehicle has no shock mount (urethane or rubber flexible cushioning) at the differential or the transmission? That doesn't sound very well thought out by the folks who built (assembled?) it. I wonder if you'd be well-served by having a reputable builder go over it and make some suggestions.
I know this post looks harsh. I don't mean to be parental here! I simply care.
