Lost all my coolant
Old Nov 18, 2013 | 12:13 AM
Boodrow379's Avatar
Boodrow379
Lost all my coolant
I have a 2wd 78 250 Ranger with a 460 and c6. It runs great, but I really dont use it much, I start it every few days just because. Heres my situation, I cleaned my motor with a steam cleaner/pressure washer, then drove it around town and stopped at a guys house and was parked for a minute and theres half a gallon of coolant on the ground. Took it back to the property where I had it, lost all my coolant on the way there, left puddles at all the stop signs lol. The freeze is coming out from under the heater-cor. It is not coming out of a crack put a little pipe about 1/2 an inch long on the bottom of the heater core. My question is did I just blow off a plug to a drain hole on the heater.. or is there something internally wrong. I am thinking it is a drain to flush the system or something and I was going to go ahead and plug it but I dont want to ruin anything, sorry to be so wordy
Old Nov 18, 2013 | 03:09 AM
rockittsled's Avatar
rockittsled
possibly the heater core failed and drained out of the AC condensation drain line
Old Nov 18, 2013 | 04:53 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Yep rockittsled is dead on, sounds like a heater core failure. Just bypass the heater core (take both lines off the heater core fittings in the eng compartment and connect them to each other) till you can get to replace the core.
Yea no heat, but no leak either. Once you top of the radiator, it should not leak out anymore.
Old Nov 18, 2013 | 09:31 PM
Boodrow379's Avatar
Boodrow379
So its not possible that I just blew off a plug? Thank you for the reply
Old Nov 18, 2013 | 10:16 PM
77&79F250's Avatar
77&79F250
No plug in the system to blow off, as far as I know.
Old Nov 18, 2013 | 10:40 PM
Boodrow379's Avatar
Boodrow379
Ok I'll bypass it for now, thank you again
Old Nov 19, 2013 | 05:30 AM
77&79F250's Avatar
77&79F250
Just be aware you will NOT have any hot air to defrost the windows, and I am sure its get cold in NM too.
Old Nov 21, 2013 | 11:14 PM
Boodrow379's Avatar
Boodrow379
ok, and Ill just light a candle or something haha
Ford SD
Jun 15, 2016 04:13 PM
sanders92
1978 - 1996 Big Bronco
Jan 18, 2016 08:51 AM
choate
Jan 2, 2015 06:05 PM
iceman320
17
Oct 25, 2011 07:08 PM
britt
Modular V10 (6.8l)
Sep 11, 2009 08:00 PM
