Front springs
Old Nov 17, 2013 | 03:27 PM
milehi_350's Avatar
milehi_350
Front springs
My buddy and I installed new front springs and shocks yesterday (leveling kit). On the drivers side the tit on the bottom of the spring didn't get all the way into its hole on the axle. Their is about an 1/8" gap between the bottom of the spring and the axle. Do you guys think I need to address it or will it be okay?
Old Nov 17, 2013 | 03:30 PM
glockholiday's Avatar
glockholiday
I would get it right.
But before all of the manual labor that you are trying to avoid I would take some or all of the weight off the axle with a jack, loosen the u-bolts and try some mechanical agitation (Sledge Hammer).
Old Nov 17, 2013 | 03:32 PM
MalwareDRay's Avatar
MalwareDRay
I would want my springs sitting perfectly on that axle.
You could either open up the hole or grind the bolt down to fit.
There is a lot counting on that spring to work properly and it not sitting right is kind of a gamble in my eyes
Sent from my Galaxy Note 3 using IB AutoGroup
Old Nov 17, 2013 | 06:13 PM
F350-6's Avatar
F350-6
Get it right. First try some bumps at slower speeds on an empty road and see if it pops into place by itself. Then tighten the bolts properly.
Old Nov 18, 2013 | 12:08 PM
SuperDutyScaler's Avatar
SuperDutyScaler
most likely there is rust packed into the center pin hole, remove the u-bolts and lift the spring out of the way then clean the hole out and reinstall the spring. If it doesnt go in then you have another weird issue. And even after you torqued the ubolts down the spring didnt seat in fully? I would fix this ASAP
Old Nov 20, 2013 | 02:33 PM
milehi_350's Avatar
milehi_350
No it never seated fully. I made sure that the hole was clean.
I tried to fix it myself, got everything loose, pried, racked, whacked and hammered and still couldn't get it. We'll my cousin is the service manager at one of the local dealers and he gave me a deal on mounting my new tires and an alignment so I had the tech who alighned it take a look. He got it apart and took some measurements and found that the dowel was longer than the hole was deep. A little bit of grinder work and it's good to go.
Hopefully anyone doing a leveling kit with a front spring swap will read this and check dimensions before installing the new springs. (Although you wouldn't think it would be necessary)
Old Nov 20, 2013 | 02:56 PM
HKusp's Avatar
HKusp
Thanks for reporting back what the issue was. It will be helpful to someone in the future.
Old Nov 20, 2013 | 04:21 PM
MalwareDRay
Yep.. exactly what I thought. Had to do it to mine so figured it's what you had going on too.
Jason302
Aug 23, 2011 08:01 PM
low 66
15
Oct 12, 2010 01:31 AM
250FordTruck
19
Dec 19, 2009 12:36 AM
nhill2090
Jul 7, 2008 09:25 PM
kevkel
Dec 24, 2004 09:22 PM
